Can't export
Can't export
Postby KekkoZ » Thu Dec 30, 2010 11:40 am
I have searched a lot but I haven't found any solution for my problem: I can save and load my models but i can't export them. I use Makehuman 1.0 alpha 5.1 with Windows 7 Ultimate 64 bit.
When I try to export a model nothing happens and in the folder "exports" of makehuman there isn't anything.
This is the outptout of the console:
Trying to open shared/mhx/templates/vertexgroups-common25.mhx
Closing shared/mhx/templates/vertexgroups-common25.mhx
Trying to open shared/mhx/templates/vertexgroups-classic25.mhx
Closing shared/mhx/templates/vertexgroups-classic25.mhx
Trying to open shared/mhx/templates/vertexgroups-toes25.mhx
Closing shared/mhx/templates/vertexgroups-toes25.mhx
Trying to open shared/mhx/templates/shapekeys-facial25.mhx
Closing shared/mhx/templates/shapekeys-facial25.mhx
Trying to open shared/mhx/templates/shapekeys-extra24.mhx
Closing shared/mhx/templates/shapekeys-extra24.mhx
Trying to open shared/mhx/templates/shapekeys-body25.mhx
Closing shared/mhx/templates/shapekeys-body25.mhx
Trying to open shared/mhx/templates/mhxipos.mhx
shared/mhx/templates/mhxipos.mhx closed
No file C:\Users\Francesco\makehuman\proxy.cfg
No file C:\proxy.cfg
Using config file C:\Program Files (x86)\Makehuman\proxy.cfg
Proxy configuration: Use ['Obj', 'Mhx']
   ('Proxy', True, True, True, ('./data/templates/forsaken.proxy', 'Proxy', 2))
   ('Clothes', True, True, True, ('./data/templates/sweater.mhclo', 'Clothes', 4
   ('Clothes', True, True, True, ('./data/templates/jeans.mhclo', 'Clothes', 4))
Trying to open shared/mhx/templates/shapekeys-bodylanguage25.mhx
Closing shared/mhx/templates/shapekeys-bodylanguage25.mhx
Trying to open shared/mhx/templates/common-armature25.mhx
Closing shared/mhx/templates/common-armature25.mhx
Trying to open shared/mhx/templates/rig-armature25.mhx
Closing shared/mhx/templates/rig-armature25.mhx
Trying to open shared/mhx/templates/materials25.mhx
Closing shared/mhx/templates/materials25.mhx
Trying to open shared/mhx/templates/meshes25.mhx
Trying to open shared/mhx/templates/vertexgroups-bones25.mhx
Closing shared/mhx/templates/vertexgroups-bones25.mhx
Trying to open shared/mhx/templates/vertexgroups-leftright25.mhx
Closing shared/mhx/templates/vertexgroups-leftright25.mhx
Trying to open shared/mhx/templates/vertexgroups-cage25.mhx
Closing shared/mhx/templates/vertexgroups-cage25.mhx
Closing shared/mhx/templates/meshes25.mhx
Trying to open shared/mhx/templates/proxy25.mhx
Closing shared/mhx/templates/proxy25.mhx
Trying to open shared/mhx/templates/rig-poses25.mhx
Closing shared/mhx/templates/rig-poses25.mhx
Thanks to all in advance :D
KekkoZ
Re: Can't export
Postby mflerackers » Thu Dec 30, 2010 11:57 am
Did you try Makehuman 1.0 alpha 5.1b?
MakeHuman project Developer
mflerackers
Re: Can't export
Postby Beta-Tester » Thu Dec 30, 2010 12:08 pm
what version did you use - 5.1, 5.1a or 5.1b ?
if you didn't use the current version 1.0.0 alpha 5.1b, take a look for something like this:
"C:\Users\<your username>\AppData\Local\VirtualStore\Program Files (x86)\Makehuman\㩃啜敳獲浜楡䅮浤湩䑜捯浵湥獴찀Ȭ歰ȑ��\makehuman\exports"
normaly there should be your exported file...
there is a newer version (makehuman1-0-0_alpha51b_win32.exe) downloadable via
http://makehuman.googlecode.com/files/makehuman1-0-0_alpha51b_win32.exe
or
http://code.google.com/p/makehuman/downloads/detail?name=makehuman1-0-0_alpha51b_win32.exe
this version will fix that issue with the exporting path...
BUT on my system and that version 5.1b of makehuman, in the exported file, i am missing many things, no clothes anymore, no bone shapes anymore, no low poly human anymore, ... on none of the layers.
my system:
win 7 x64 ultimate de-DE
blender 2.55 x64 - official release
makehuman 1.0.0 alpha 5.1b - official release
Beta-Tester
Re: Can't export
Postby joepal » Thu Dec 30, 2010 12:34 pm
Beta-Tester wrote:blender 2.55 x64 - official release
Well, that's your problem right there. Since the 2.55 beta release there has a) been api changes and b) been changes to the MHX format.
To ensure compatibility you need a later build from http://www.graphicall.org/builds/ and copy io_import_scene_mhx.py from the makehuman distribution and use it to overwrite the file with the same name in the blender distribution.
Or you could wait a day or two. Reading the blender dev notes, it seems a new official blender beta is about to be released, and it'll contain up to date versions of everything.
Re: Can't export
Postby KekkoZ » Thu Dec 30, 2010 12:50 pm
Thanks to all for the replies; I use MakeHuman 5.1b, and I will import the model of Makehuman in Blender 2.49b...
@Beta-Tester there isn't any folder after "C:\Users\<your username>\AppData\Local\VirtualStore\Program Files (x86)\Makehuman\" in my system.
KekkoZ
Re: Can't export
Postby mflerackers » Thu Dec 30, 2010 1:02 pm
It should be in /My Documents/makehuman
mflerackers
Re: Can't export
Postby KekkoZ » Thu Dec 30, 2010 1:05 pm
mflerackers wrote:It should be in /My Documents/makehuman
thank you very much! I didn't see before that the exported models were here :D
KekkoZ
Re: Can't export
Postby Beta-Tester » Thu Dec 30, 2010 9:15 pm
thanks for that information... but why to wait one or two days...
the official release of Belnder 2.56 is already released !!! =D
:D :lol: :mrgreen:
Beta-Tester
