Trouble with Retarget BVH
Re: Trouble with Retarget BVH
Postby tomcat » Wed Mar 08, 2023 8:27 pm
PayItForward wrote:But wait? You work with a translator? For everything? I didn't notice that, at all.
Yep, I have a very poor ability with languages. One of the main reasons I haven't evacuated yet. I recommend it — DeepL :D
You need to repeat this for the other shoulder bone and the upper arm bones
Now I kind of get it. If the shoulder tilt is corrected, then the arm will follow.
Yeah, a few animations can be changed that way, but if you have to do it en masse… it gets a little sad.
But why did you say
bone roll of the legs
specifically the legs?
Postby PayItForward » Wed Mar 08, 2023 8:46 pm
:D you already told me about DeepL but I had no idea how good it is. It's actually a bit scary. :shock:
Yes, you see it in the picture. Correcting the shoulder will force you to correct the upper arm as well. And then there's still the problem with the neck. I personally hope somebody will find a technical solution, though.
That's the problem, yes. For me it's bearable since I don't need that many animations but CMU has like 3,000 animations. I have downloaded the videos http://mocap.cs.cmu.edu/allavi.zip and watch what I need before. So yeah, it's all about making good decisions beforehand.
legs
Well, not specifically. :) But I have encountered the problem mostly with legs that rotate completely unnatural. Maybe other bones are also wrong but perhaps just not noticable.
twitter.com/ChristophCrane_ (Indie author & game developer)
PayItForward
Postby PayItForward » Thu Mar 09, 2023 6:08 pm
I got a bit farther with Retargeter BVH. After some further testing I'm even more convinced that the root of the problem is the T-pose that was added later to the CMU animation data. More specifically, it isn't even a true T-pose but a mixture of a T- and an A-pose (see image: C).
That's fine by itself, btw, but the problem is, the more this pose differs from the 'rest pose' that comes with Makehuman (i.e. usually image: A) the more incorrect the result will be.
So to get a perfect result you basically need a 'rest pose' which is virtually identical with the 'rest pose' in the CMU animation data (B=C!). Since Makehuman right now has no pose that comes close to the pose needed I made one on my own (see image: B).
It leaves still a lot to be desired. There are issues with the neck in some animations, also with the toes, and the shoulders. The shoulders sit so deep in the CMU rig that I don't really know how to reproduce this effect in my pose.
I attached my T-A-pose so you can test it if it works for you.
Now I'm going to test if the same is true for the ACCAD male BVH. :ugeek:
Rest T-A.bvh
MH default righ T-A pose
(43.05 KiB) Downloaded 120 times
PayItForward
Postby tomcat » Thu Mar 09, 2023 8:03 pm
PayItForward wrote:I attached my T-A-pose so you can test it if it works for you.
Well… it works!
Blender 3.4.1
In fact, I'm editing the translation a bit. Although I have no aptitude for languages, I have studied Polish and Hebrew… and even the language of the island aborigines… which the world is trying to speak.
That's probably the hardest part… one never knows in advance which decision will turn out to be the good one.
__
By the way, an interesting plugin for Blender, in case you need it.
Postby tomcat » Thu Mar 16, 2023 11:43 pm
Some reflections on ancient problems. That the poses and movements of the characters would be more natural. The idea was this.
1. Rig should take into account the size of the joint (bone thickness). A similar thing is done in Z-Anatomy. BIOMECHANICS.
Here is the MakeHuman rig:
And this is the rig of an anatomically correct skeleton:
My suggestion is to add bones that would compensate for the size of the joints:
  • Rig MakeHuman
  • Rig with joint compensation
For a correct rig, you need to consider the size of all the joints. For a light (gaming) one, I think the elbow, hip and knee joints would be enough.
2. The presence of "control bones". Similar to those in Biomechanics blender:
Bending the knee or raising the arm causes movement of connected bones that move together. For example, raising the arm causes simultaneous movement of the shoulder and collarbone:
3. And, of course, the spine, which consists of several vertebrae.
4. And a slight movement of the jaw sideways.
Unfortunately, this is really a lot of work… perhaps even too huge.
It is impossible to do everything at once and perfectly… but you can try to determine the vector of development and lay the foundation.
Postby RobBaer » Sat Mar 18, 2023 12:00 pm
Really interesting insights, and well illustrated. Thanks for sharing.
Postby tomcat » Sun Mar 19, 2023 2:46 pm
@RobBaer Thanks for the response! If my points were taken without negativity, I'll continue my thoughts.
Soft tissue muscle and fat — rig or shape?
I tried to find the most decent picture on this subject.
Muscle work and fat sway in motion. No revelations, just a comparison of known solutions.
Rig (extra bones):
+ easy to implement, require few resources when used in animation (which is important in games).
- limited in possibilities.
Shape Keys:
+ more morphing possibilities.
- difficult to create (sculpting targets).
Different situations benefit from different approaches. In my opinion, one of the main advantages of MakeHuman is variability, adaptability to different, often conflicting requirements. It is possible to choose the detailing of models or rig more suitable for a particular purpose. Therefore, it is desirable to leave this approach and let users choose.
Postby PayItForward » Thu Mar 23, 2023 6:38 pm
tomcat wrote:Although I have no aptitude for languages, I have studied Polish and Hebrew… and even the language of the island aborigines… which the world is trying to speak.
Now that's quite a combination :shock:
Just ask me how many pages I've written that never made it into the final book. :)
biomechanical skeleton
Hard to imagine seeing this anytime soon. I was always hoping somebody would make something in Blender similar to 3Dmax' Bipeds with physical correct bone restrictions but there really seem to be larger issues making that unlikely.
PayItForward
Postby tomcat » Fri Mar 24, 2023 5:46 pm
Well, it's already done in Z-Anatomy - BIOMECHANICS (link at bottom of page): proper bones and constraints. The problem is to make children's skeletons, for growing characters.
Postby PayItForward » Fri Mar 24, 2023 6:31 pm
oh yes, I noticed. It's great but I meant something like that in Blender. I tried to make a skeleton with natural bone restrictions in Blender years ago but it never turned out good. Would be fun to have it react to the physics engine.
PayItForward
