problem
problem
Postby wulff420 » Sat Dec 18, 2010 11:17 am
first off hi yall, great program ya got here
nightly December 18 2010 is not working at all when i try it it flashes the command prompt screen and shuts right off
thanks tho keep up the good work i like this program alot
edit: i checked again and re downloaded nightly 12 18 10 and it is not working at all sorry to bug, i did exactly as i did installing 12 17 10 but for some reason i run the .exe for the new one and all that hapens is the comand prompt window flashes on and then right off no writing or anything its like an empty .exe sorry again and thanks
wulff420
Re: problem
Postby jcapco » Sat Dec 18, 2010 10:50 pm
are you using windows vista or higher?
jcapco
Re: problem
Postby wulff420 » Sun Dec 19, 2010 7:42 am
no windows xp i downloaded the win 32 version the last nightly worked for me but lastnites dint was all i hope tonights works out bout ta look for it now
wulff420
Re: problem
Postby wulff420 » Sun Dec 19, 2010 7:56 am
good news tonights nightly opend right up it works again yay
bad news tho i still get error messages trying to import into blender via collada
wulff420
Re: problem
Postby mflerackers » Sun Dec 19, 2010 9:08 am
To import into blender use mhx instead of collada.
MakeHuman project Developer
mflerackers
Re: problem
Postby wulff420 » Sun Dec 19, 2010 1:19 pm
mhx is it thanks
but will it come with the armature like collada does?
wulff420
Re: problem
Postby mflerackers » Sun Dec 19, 2010 1:24 pm
It comes completely rigged and ready to animate, it is a special format to support all blender features, it is much more detailed than the collada export.
mflerackers
Re: problem
Postby wulff420 » Sun Dec 19, 2010 7:55 pm
oh wow thank you kool this team is great
is 2.49 blender alright tho i use that i like the interface better
wulff420
Re: problem
Postby chufu » Sun Dec 19, 2010 10:29 pm
I have an other Problem.
The 1.0alpha XX Versions dosn't start on my OS.
There is a Syntax-Error in the Python Start Script.
The Message is this:
'import site' failed; use -v for traceback
Traceback(most recnt call last):
File "<string>", line 1, in <module>
File "main.py", line 53, in <module>
import os
File "C:\Programe\Psthon\Libß_abcoll.py", line 80, in <moule>
from _abcoll import MutableMapping # Can't use collections (bootstrap)
File "C:\Programme\Python\Lib\_abcoll.py", line 54
class Hashtable(metaclass=ABCMeta):
SytaxError: invalid syntax
Could not run main Python script
My OS ist Win XP SP3 on to a Single Core Pentium with 2,53GHz and 2GB RAM.
Greatings
Peter
chufu
Re: problem
Postby joepal » Mon Dec 20, 2010 12:27 am
This looks like you have another python version installed on your computer and that it takes predesence over the one shipped with makehuman.
MH will at the moment assume the 2.6.x python included in the zip and may behave in a somewhat random fashion if another (especially an earlier) version of python is installed.
You could try to temporarily disable or uninstall the other python and see if that is the problem.
Users browsing this forum: No registered users and 9 guests
