Android build
Android build
Postby FATHEROFBOSS » Thu Dec 10, 2020 5:43 pm
Dear admin please pls build an Android version of make human if make human has an touch support like wacom then u don't need to change the UI completely and just make touch support default . Smartphone are getting better and better blender and make human should be available for Android and other software like cad etc Devs should start to rely on Android smartphone cause the smartphone specs has already reached at this point that laptop had this specs not so long ago
FATHEROFBOSS
Re: Android build
Postby loki1950 » Thu Dec 10, 2020 5:50 pm
Further complication we use OpenGL for rendering that is not available under Android so several other major sections of code would need to be rewritten you need to look at all the dependencies.
Re: Android build
Postby FATHEROFBOSS » Fri Dec 11, 2020 10:02 pm
loki1950 wrote:Further complication we use OpenGL for rendering that is not available under Android so several other major sections of code would need to be rewritten you need to look at all the dependencies.
So will you build it
FATHEROFBOSS
Re: Android build
Postby loki1950 » Fri Dec 11, 2020 10:34 pm
No we will not we do not have the resources for a project that would take maybe a year to do as all of the graphics would need a complete redesign from OpenGL to GLES the display language that is used in Android and there are no Python bindings for GLES to use our GUI library Qt5 that means no GUI at all is available till some group writes the Python bindings for Qt5/GLES.
