Generating images
Generating images
Postby Supreetha » Fri Apr 26, 2019 11:33 am
I am trying to generate images of the MakeHuman models using a Python script. First, a database is generated which contains certain values for human body parameters like, height, chest size, waist size, etc. Using this database, I want to generate images whose measurements are mapped to the ones in the database. The images are getting generated, but I am not able to spot the difference in measurements in the images.
Can anyone please help me out in this?
Supreetha
Re: Generating images
Postby joepal » Sat Apr 27, 2019 1:04 pm
If you take a look in https://github.com/makehumancommunity/m ... ripting.py, for example lines 571-575, you can see that it runs both applyTargets and redraw. The screen dumping procedure (line 593) simply takes the viewport and saves it to a file. So in order to save a modified file, the viewport needs to be redrawn before dumping the image.
Return to Python scripts
