will models compatible with 1.1.x work with 1.0.2?
Postby injinji » Mon Aug 07, 2017 2:24 pm
I had problems using MH 1.1.x on my PC, so I am using 1.0.2, will models, targets, and anything else compatible with 1.1.x work on 1.0.2?
injinji
Re: will models compatible with 1.1.x work with 1.0.2?
Postby joepal » Mon Aug 07, 2017 3:11 pm
They might, but there is no guarrantee. In the other direction there are compatibility helpers. I.e a model made with 1.0.2 can be loaded with 1.1.1. But there are no compatibility helpers for backwards compatibility, so if it works at all to load a 1.1.1 asset in 1.0.2, chances are you'll experience glitches.
