Prelim Ballet set (and some asset questions)
Postby badwolf » Thu Apr 28, 2016 4:09 pm
okay i have (with some help) lashed up a few ballet items with some bonus materials
https://dl.dropboxusercontent.com/u/539 ... letset.zip
unzip and put all the folders in your Clothes folder (the materials folder goes in clothes also so you can use it with all the items)
now the questions
1 could somebody give me advice on how to make a sleeveless and a shoulderless version of the leotard??
2 how do i go about removing my previous assets (they are way too crude)?
3 anybody want to help make slippers and leg ribbons??
badwolf
Re: Prelim Ballet set (and some asset questions)
Postby joepal » Thu Apr 28, 2016 5:38 pm
2: You should be able to go to the asset, click edit, and then at the bottom of the page click delete (assuming we're talking about the repo area).
Postby badwolf » Thu Apr 28, 2016 6:48 pm
joepal wrote:2: You should be able to go to the asset, click edit, and then at the bottom of the page click delete (assuming we're talking about the repo area).
that worked
any opinions on the assets?? (i also have a pair of tights that are tweaked to work with the leo)
badwolf
Postby joepal » Fri Apr 29, 2016 7:19 am
badwolf wrote:any opinions on the assets?? (i also have a pair of tights that are tweaked to work with the leo)
I don't understand what I'm seeing. Is this how it's supposed to look?
Postby badwolf » Fri Apr 29, 2016 12:05 pm
i was going for a proof of concept before i tried to do anything fancy so
1 yes it is very thin
2 minimum of verts
im not sure but the fit is more or less correct (anybody know any ballet dancers??)
badwolf
Postby badwolf » Fri Apr 29, 2016 5:50 pm
oh btw i had a friend lash up a script so that i could make the full html 4.01 color set of simple materials is there somewhere i could post the whole set without doing them one by one??
until a better place is found
https://dl.dropboxusercontent.com/u/539 ... 282%29.zip
all of these diffuse colors from the HTML 4.01 standard
badwolf
Postby joepal » Fri Apr 29, 2016 6:20 pm
Cool. :-)
Lacking better options, I think this would the best place atm: https://github.com/makehumancommunity/c ... assets-wip
Once 1.1.0 is out I'm planning on adding another repo largely intended for plugins which will accept zip files though.
Postby badwolf » Fri Apr 29, 2016 6:41 pm
joepal wrote:Cool. :-)
hints on how and where to do the upload?? (start with how do i get write access??)
badwolf
Postby joepal » Fri Apr 29, 2016 6:45 pm
It's a normal git repo and the instructions on how to get write access is on the front page. Just PM me your github username and I'll give you commit access.
Postby badwolf » Sun May 01, 2016 5:39 pm
just leaving this for future readers
the set now has
140 simple colored materials (each one is from the HTML 4.01 named color set)
a full sleeve leotard
a sleeveless leotard
2 versions of a flat platter tutu
a pleated platter tutu
a cheerleader skirt style tutu
and soon will have a pair of slippers and ribbons
badwolf
