makehuman Mudbox UE4 Problem
Postby Taratus » Wed Apr 15, 2015 6:45 am
When I export a makehuman model from Mudbox, the eyes and teeth are separated from the body, is there a way to fix that?
Taratus
Re: makehuman Mudbox UE4 Problem
Postby duststorm » Wed Apr 15, 2015 8:44 am
Separated as in: not rigged? Or a separate object?
The eyes and teeth are exported as separate objects, all rigged to the same skeleton. This is normal. But most tools, such as maya, max, and perhaps mudbox too should allow you to join these objects into one mesh if you desire so.
Postby Taratus » Wed Apr 15, 2015 3:26 pm
The Objects are separated, but when I import the version from Makehuman they are one skeletal mesh.
Taratus
Postby duststorm » Thu Apr 16, 2015 7:44 am
It's probably a setting in Mudbox, but I'm not familiar enough with it to be able to help you.
Perhaps asking the mudbox community directly would be a better idea. As I understand, the problem is that if you import an FBX file with a skeleton parented to multiple meshes/objects in Mudbox, and export it again, the link between skeleton and the other objects is lost.
