makehuman+Ogre model problem
Postby robel » Sat Apr 12, 2014 11:09 am
hope i get solution to my problem
i animate my model using bvh files manually .
So i create model using makehuman , i select armature model , and i export it as i use ogre , i export it to ogre3d formt
when i read the .skeleton
i get it have
hips,thigh.L
hips,thigh.R
as bones , i said ok
but when i export it as .bvh file i get this joints (or bones)
hips,__thigh.L,thigh.L
hips,__thigh.R,thigh.R
why in my skeleton file i don't have "__thigh.L" and"__thigh.R"
i need them because in my programe i use nbones names to animate the model
for exemple
if skel->getBone(i)== bvh_name(j) // animate bone (i) using the orientation of the joint in the bvh file
so i will never use __thigh.L of the bvh file ,
robel
Re: makehuman+Ogre model problem
Postby robel » Sun Apr 13, 2014 9:05 am
HI there
there is noway to turn off dummy bones in the bvh file ?
robel
Postby ThomasL » Mon Apr 14, 2014 8:52 am
Dummy joints seem to be hardcoded into the bvh exporter currently. It should be easy to make it into an export option instead.
ThomasL
Postby duststorm » Mon Apr 14, 2014 10:13 am
The API supports this already, it's just not a GUI option.
Exporting dummy joints in BVH is a sane option as it is the only way to get consistency across all importers. Dummy joints are easily ignored (it does not hurt if you do not set or read their orientation, they usually have no animation data of their own). Ignoring joints with names starting with '_' is probably what you will want to do in your code.
Otherwise, you can use the shell in MH and enter the following to export a BVH without dummy joints:
import gui3d
human = gui3d.app.selectedHuman
import bvh
b = bvh.createFromSkeleton(human.getSkeleton(), animationTrack=None, dummyJoints=False)
b.writeToFile("path/to/my/file.bvh")
Perhaps we could add the option to the gui, but I wonder how often it will be used. More importantly, how to call the option? "Export dummy joints" is correct but might sound like chinese to many. If added it should be accompanied with the necessary documentation. But perhaps the documentation in the bvh.py module can be quickly converted.
