POV-Ray path fault?
POV-Ray path fault?
Postby Rapscallion » Thu Aug 08, 2013 6:41 pm
Hello,
I understand that the render options in MH are still experimental but the solution to this bug might be simple.
Don't know if any one else is aware of, or has experienced this but the POV-Ray render option gives me the following message box if I choose the export and render option:
POV-Ray not found
You don't seem to have POV-Ray installed or the path is incorrect.
This is despite having typed the correct path in the provided field.
I'm using POV-Ray version 3.62 and by default the executables (pvengine.exe and pvengine-sse2.exe) install to c:\program files\pov-ray for windows v3.62\bin
My insallation of POV-Ray works fine on its own.
Regards to all.
Rapscallion
Re: POV-Ray path fault?
Postby Manuel » Thu Aug 08, 2013 7:03 pm
Can you try to use the [...] button to locate the folder with binary, instead to write it by hand?
What operating system are you using?
Postby Rapscallion » Thu Aug 08, 2013 7:30 pm
Hi Manuel,
I'm using MH V1.0 alpha7 with Windows XP Pro (service pack 3).
I don't have a [...] button.
I checked the path about three times to ensure that I was typing it correctly.
Thanks.
Rapscallion
Postby Manuel » Thu Aug 08, 2013 8:08 pm
Ah...alpha7.
Povray support is less than experimental in it.
I'm sorry the alpha8 nighlty are not yet ready for download: all these things are fixed.
We are working hard to restore the nightly soon.
Postby Rapscallion » Thu Aug 08, 2013 8:32 pm
Okay Manuel, thanks for your response and the hard work of the MH team. I look forward to alpha8. :)
Rapscallion
Postby Manuel » Thu Aug 08, 2013 9:05 pm
Rapscallion wrote:Okay Manuel, thanks for your response and the hard work of the MH team. I look forward to alpha8. :)
If you want I can tell you how to try the alpha8 from svn.
It require an svn client, python 2.7 and some python tools. No build is required since alpha8 is pure python.
Postby Rapscallion » Fri Aug 09, 2013 9:38 am
Please do! I'd love to give it a try.
Rapscallion
Postby Manuel » Fri Aug 09, 2013 9:42 am
Do you know how svn works?
Postby Rapscallion » Fri Aug 09, 2013 10:02 am
Manuel wrote:Do you know how svn works?
No I don't. But, if it is downloadable I'll download it and look at how to use it.
Rapscallion
Postby Manuel » Fri Aug 09, 2013 10:53 am
Are you working in Windows?
