Mhs_mouth compression not found
Postby sam1_64 » Fri Mar 22, 2013 10:48 am
Hello, my problem is that when I make lip sync on mhx model with papagayo moho .dat on blender, the animation is gone if I close blender and reopen the blend file, even the keyframes are still there in the timeline. If I then click for example reset visemes button I get this error;
File "C:\Program Files (x86)\Blender Foundation\Blender\2.65\scripts\addons\io
_import_scene_mhx.py", line 3718, in execute
clearMhmProps(rig, shapekeys, self.prefix, context.tool_settings.use_keyfram
e_insert_auto, context.scene.frame_current)
_import_scene_mhx.py", line 3804, in clearMhmProps
rig.keyframe_insert(prop, frame=frame)
TypeError: bpy_struct.keyframe_insert() property "Mhsmouth_compression" not foun
d
I have read the documentation on lip sync and can't figure out what I'm doing wrong :|
sam1_64
Re: Mhs_mouth compression not found
Postby ThomasL » Sat Mar 23, 2013 5:36 am
Should be fixed in r4855. You need to download an up-to-date Blender from graphicall.org (available tomorrow or so), or copy the mhx importer from MH svn to Blender addons directory.
ThomasL
Postby sam1_64 » Sat Mar 23, 2013 7:34 am
ThomasL wrote:Should be fixed in r4855. You need to download an up-to-date Blender from graphicall.org (available tomorrow or so), or copy the mhx importer from MH svn to Blender addons directory.
Thank you Thomas, I'll try that graphicall blender when available, but meanwhile copying the mhx importer from MH svn didn't help and the problem persist. :roll:
sam1_64
Postby sam1_64 » Sat Mar 23, 2013 9:25 pm
Thank you, working now. I updated the MH svn and copied the mhx importer to blender, and didn't even need to upgrade blender :)
sam1_64
Postby aay9203 » Wed Apr 17, 2013 3:04 pm
I am having the same problem in r4961
mhx_mouth compression cannot be found once the blender is closed and reopened. All mouth animation are ineffective.
Need help
aay9203
Postby ThomasL » Thu Apr 18, 2013 4:10 am
It is not enough to updata MH, since the bugfix is on the Blender side. You need a fresh Blender from graphicall.org, or copy tools/blender26x/mhx_import/io_import_scene_mhx.py to Blender's addons directory.
ThomasL
