Read values via CLI interface
Postby b4rosz » Fri Oct 16, 2020 10:16 am
Hello all!
I have been trying to read the heightCm value via CLI, is there any ready-made solution?
I found in socket plugins (https://github.com/brueli/community-plu ... odifier.py) applyModifier method for setHeight applied - here it works and now I would like to read height in cm using socket CLI.
A good solution would be to use a ready-made method, but I can only use it in the build-in Mahekuman shell:
G.app.selectedHuman.getHeightCm()
>>136.58567428588867
Can this be triggered by socket CLI? I need to bring this value out.
Thank you for your help!
b4rosz
Re: Read values via CLI interface
Postby joepal » Fri Oct 23, 2020 1:44 pm
The socket plugin only exposes a few methods. If you want more information, you'd have to add another wrapper method.
Since you already know what call you want to make, that should not be rocket science. In https://github.com/makehumancommunity/c ... meshops.py add another method "getHeightCm" using the same pattern as the other methods. Without testing, something like:
def getHeighCm(self,conn,jsonCall):
    jsonCall.data = G.app.selectedHuman.getHeightCm()
Add the method in the method array in the init method, using the same pattern as on line 23.
Return to Python scripts
