how difficult would it be to make a plugin that will load a set of measurements from a CSV file ??
workflow would be
load gender and age from the first two lines and then run the measurements tab from the rest of the file
joepal wrote:If all you do is corresponding to moving the measurements sliders on the measurements tab: probably not that hard.
Since the measurements tab is already a plugin, my suggestion is to copy and modify it to fit your needs.
See https://bitbucket.org/MakeHuman/makehum ... ew-default
