Does anyone know of a FREE bvh reading program for windows
Postby Shaba1 » Fri Jan 03, 2020 11:40 pm
I just need something that will tell me how many frames a bvh animation is BEFORE I import it into blender so that I can adjust the blender timeline. As it is any frames beyond what you have the blender timline set to just get cut off. As if they are not in the file. I know this becasue I tried importing a bvh and it did not look right so I lengthen out tha timeline from the default 250 frames to 500 frame and reimported the same file from scratch and viola there were more frames.
I have BVHacker. It works but the screen for it opens up full screen on my laptop and cannot be resize( I have tired) so the bottom of the screen where the number of frames of the .bvh file is cut off.
I have tried avimator and qvavimator. Both of them crash at random times.
Shaba1
Re: Does anyone know of a FREE bvh reading program for windo
Postby RobBaer » Sat Jan 04, 2020 8:50 pm
FWIW, like you, I just change the end frame to a huge number temporarily. Most of the Window programs I used are not as good as the defunct BVHhacker and are not worth the energy IMHO.
Postby punkduck » Tue Mar 17, 2020 6:55 pm
Shaba1 wrote:I just need something that will tell me how many frames a bvh animation is BEFORE I import it into blender so that I can adjust the blender timeline.
Oh I did not see this. But the solution is not that complicated.
bvh files are ASCII afaik. Starting with the description of the skeleton, then a line with the number of frames (n) and then n lines with the values needed for rotation etc. (so one per frame)
For linux it is easy, simply use cli:
grep "Frames" *.bvh
Human_Bike_DW_3.bvh:Frames:   1313
Human_CWheels_DW_1_short.bvh:Frames:   4194
Human_CWheels_DW_2.bvh:Frames:   1421
Human_Hoop_Roll_DW_1.bvh:Frames:   797
Human_Run_DW.bvh:Frames:   281
TPose_DW.bvh:Frames:   26
If you only need to know this then also for windows there must be something similar to search for the text "Frames" ... maybe on CLI or maybe in a filebrowser. So for that task you only need a tool for searching a specified text.
Postby loki1950 » Tue Mar 17, 2020 8:22 pm
On Windows try notepad++ a very good text editor which should handle ASCII quite easily.
Return to Off topic
