Digging around for animations?
Postby Mr909 » Mon Feb 02, 2015 1:33 am
I was wondering, and I've done a little research, is there anywhere with a fairly expansive library of human skeleton animations? I have little to no animation experience and frankly don't care much for high quality graphics, though I keep thinking there's GOT to be something like this out there.
I want to animate a high fantasy game, and I need some attack animations and junk, stuff you wouldn't just find anywhere. But it's gotta be somewhere, right?
The other idea I had: Isn't it theoretically possible to "rescale" animations for different, but similarly laid out, skeletons? I mean, MH has not one, but several different rigging types, and I imagine if I could find a few of those libraries, I could probably work up an algorithm to clean them for different skeletal layouts. I'm usually not very physics-minded in my programming pursuits, but it definitely seems doable, isn't it? Has there been anything similar attempted?
Mr909
Re: Digging around for animations?
Postby joepal » Mon Feb 02, 2015 8:37 am
MH doesn't have a specific animation format. What you are looking for is called a BVH library.
If you google for "BVH library", you'll get quite a lot of hits.
These are then used via MakeWalk: http://www.makehuman.org/doc/node/mhble ... kflow.html
Postby duststorm » Mon Feb 02, 2015 10:52 am
In this section you find some sources with free BVH content on the web: http://www.makehuman.org/doc/node/mhble ... _bvh_files
Those are also compatible with the MakeWalk tool.
Return to Off topic
