Rendering with big resolution
Postby sherlockpiano » Fri Apr 22, 2022 2:15 pm
How to render with big resolution and quality?
My pics have not the same quality as they seem in the redactor
sherlockpiano
Re: Rendering with big resolution
Postby loki1950 » Fri Apr 22, 2022 6:50 pm
Makehuman itself was never designed or intended to be used as the prime rendering platform import it into blender for hi res rendering period as we are not going to spend an other two years coding a render engine into makehuman.
Postby Ricardo2020 » Sat Apr 23, 2022 2:10 am
This one is relatively easy.
Go to the Render Tab.
Go to the Render sub tab.
Under settings, there is a text entry field wherein you can tell MakeHuman how big you want your rendered image to be.
Fill in the width and height in pixels and put an x between the two numbers.
I have mine set at 3600x2000 but you can go bigger you need be...
Postby namuhekam » Tue May 17, 2022 1:14 am
Also be aware of the sample count when upscaling a render. The render time can increase by a lot with higher resolution and along with a high sample count. You could do a high resolution render with a lower sample count to improve render time. Conversely you can do the inverse of the aforementioned method. It's only a suggestion and can be used at one's discretion.
namuhekam
Users browsing this forum: Google Feedfetcher and 1 guest
