Showing Slider Values
Postby bogdan666 » Fri Jun 21, 2019 10:29 am
Is there a way to show the slider values of a characters body? For example age 0.3555 or Lowerarm muscles 0.4456.
Sometimes I need the exact values for reusing with different characters (different head but keeping body proportions and targets from old character...).
bogdan666
Re: Showing Slider Values
Postby loki1950 » Fri Jun 21, 2019 2:25 pm
The character files are really just text files just open one with a text editor and you will see the exact value of each slider morph that is used buy that character much simpler than writing down each value from the GUI then transferring to a new character so the work flow would be create the base body type save it,then modify the face/head name that character save,reload base rinse and repeat.An lot of the time just a change in work flow is the solution ;)
Postby bogdan666 » Sun Jun 23, 2019 7:09 am
Good to know that it's as simple as it is.
Normally I'm working with a few proven body bases and change only the face, but sometimes I want to recombine some faces with different bodies, because making a good looking face is fairly challenging.
bogdan666
