Make Human Model Eports To Turntables
Postby Artist » Wed Oct 06, 2010 5:30 am
I need to export Make Human 3D models to a flash turntable for viewing in a webpage such as those shown here:
http://www.pixologic.com/blog/2010/09/new-artwork-in-the-turntable-gallery/
http://www.artstorm.net/plugins/turntable-flash-viewer/
whether by Flash or any other viewing means. What is the best way to do this?
Even better than a turntable would be the ability for the viewer to rotate the model on two axis instead of just one.
I want to export the fully colored model, not the clay image.
Artist
Re: Make Human Model Eports To Turntables
Postby mflerackers » Wed Oct 06, 2010 7:22 am
There's a Blender WebGL exporter, this would allow you to look at the object from all directions. The turntable gallery just uses a series of images, so I guess you need to make renders for different angles, turning the object or camera each time (depending whether you want the light fixed or not).
MakeHuman project Developer
mflerackers
Postby Artist » Wed Oct 06, 2010 3:40 pm
WebGL is currently only available in bleeding edge beta release browsers. Until WebGL is integrated into the stable releases I will need an alternative to WebGL.
Artist
Postby mflerackers » Wed Oct 06, 2010 4:03 pm
Well, there are some flash based renderers which take obj, you could try those.
http://www.sophie3d.com/website/index_en.php
http://www.urdalen.com/blog/?p=227
mflerackers
