Could I use the real 3D face to replace the face of model?
Postby Bingo » Mon Sep 07, 2015 9:09 am
First,thank you for creating such a great open-source project.
I have some questions want to ask for advice. Now I have a real 3D face (obtained by Structure from Motion (SfM)) that saved by the standard .obj format.
Could I use the real 3D face to replace the face of model in MakeHuman?
If so, how to do it? If not, is there any good suggestions?
best wishes.
Bingo
Re: Could I use the real 3D face to replace the face of mod
Postby joepal » Mon Sep 07, 2015 10:17 am
Yes. If you have a partial mesh, you can cut out the corresponding parts of the base mesh, paste your own vertices and tie them together with faces. Then export the result as a proxy. This can then be used inside makehuman.
You would need to do this in blender and have the MakeTarget and MakeClothes tools installed.
See http://www.makehumancommunity.org/wiki/ ... a_proxy%3F and http://www.makehumancommunity.org/wiki/ ... ologies%3F
Postby ThomasL » Tue Sep 08, 2015 7:50 am
Bingo wrote:Now I have a real 3D face (obtained by Structure from Motion (SfM)) that saved by the standard .obj format.
Could you describe what tools and workflow you used to obtain that? I imagine that a lot of people would be interested in deriving a MH face from photographs, me included.
ThomasL
Postby Déesse » Tue Sep 08, 2015 9:24 am
Something like that? http://www.123dapp.com/catch
Déesse
Postby Bingo » Tue Sep 08, 2015 2:16 pm
Software like Autodesk 123D (http://www.123dapp.com/catch) and VisualSFM (Created by Changchang Wu) .
The main principle is SFM ,https://en.wikipedia.org/wiki/Structure_from_motion .
Bingo
Postby Bingo » Tue Sep 08, 2015 2:19 pm
joepal wrote:Yes. If you have a partial mesh, you can cut out the corresponding parts of the base mesh, paste your own vertices and tie them together with faces. Then export the result as a proxy. This can then be used inside makehuman.
Thank you for your advice. I am going to try it next. Thank you very much.
Bingo
Postby joepal » Tue Sep 08, 2015 3:22 pm
As a tip before you start though: Note that all faces have to be quads for the MakeClothes tool to work. If your mesh consists of tris rather than quads, you will have to clean this up somehow. Also, it will most likely be tricky to tie the parts together if they are of vastly different mesh densities.
Postby R45k0ln1k0w » Fri Oct 16, 2015 9:37 am
You could also use blenders shrinkwrap modifier to apply your custom face shape to the makehuman mesh. This would be a non destructive way and you could retain the UV layout.
R45k0ln1k0w
Postby duststorm » Fri Oct 16, 2015 9:50 am
Or you could use a tool like R3DS Wrap, works great and you get the very functional face topology from makehuman, allowing you to apply facial animation to your custom face directly thanks to the bone face rig.
Postby R45k0ln1k0w » Fri Oct 16, 2015 10:07 am
duststorm wrote:Or you could use a tool like 3DS Wrap, works great and you get the very functional face topology from makehuman, allowing you to apply facial animation to your custom face directly thanks to the bone face rig.
could you give a link to the tool please? Is it free to use?
R45k0ln1k0w
