Alpha 8 RC - very nice, thanks to all.
Postby mercurius » Fri Feb 21, 2014 1:13 am
I just downloaded and played around with the latest.
Exported to fbx, and imported it into Modo.
The basic rig came in functional and well-weighted? Yes! I was able to pose immediately.
I can't believe it was that easy. I don't want to get to excited, but I think I can almost start a walk cycle within a minute of importing.
This is a huge improvement - and I appreciate the hard work.
A vote of thanks to the developers!
mercurius.
mercurius
Re: Alpha 8 RC - very nice, thanks to all.
Postby ThomasL » Fri Feb 21, 2014 2:16 am
Nice to hear. Especially since none of the devs is a modo user, I think.
ThomasL
Postby brkurt » Fri Feb 21, 2014 3:06 am
ThomasL wrote:Nice to hear. Especially since none of the devs is a modo user, I think.
And who would have thought that the Alpha 8 Collada export is more reliable than Poser or DAZ for working flawlessly in Marvelous Designer 3?
Actually, that's a bit unfair, because the DAZ proprietary Collada doesn't import at all into MD3. No doubt about it; Makehuman with its superior measurement system is poised to take on all the other human character creation software out there. Now MH needs a few fashion designers to come on board. ;)
Postby duststorm » Fri Feb 21, 2014 3:12 am
Great to hear that it works so well :)
Supporting many different target tools is always a challenge.
Postby slspencer » Tue Feb 25, 2014 12:47 am
Here's a link to a screenshot of Lekala's online 3d body generation:
http://sewing.patternreview.com/SewingD ... opic/84079
How could MakeHuman be used to implement something like this?
slspencer
Postby Manuel » Tue Feb 25, 2014 8:58 am
slspencer wrote:Here's a link to a screenshot of Lekala's online 3d body generation:
Yes. It's still not perfect for our high standards, but it's usable. Take a look here, in the "Measure" section.
http://www.makehuman.org/doc/node/gende ... ml#measure
Postby slspencer » Thu Feb 27, 2014 9:12 pm
This file doesn't load measure data, it was saved from version 1.0 Alpha 8 rc
https://drive.google.com/file/d/0BxsnjDIHW4yvYXJxRVhtLV9MdWs/edit?usp=sharing
Any suggestions, or should I file an issue?
slspencer
Postby slspencer » Thu Feb 27, 2014 9:21 pm
The file I listed was run in command line mode from the directory with the mhm file :
makehuman NeckHeightNeckCircum.mhm
slspencer
Postby duststorm » Thu Feb 27, 2014 11:19 pm
slspencer wrote:This file doesn't load measure data
It contains measurement data for neck height and circumference, probably because you touched those sliders before saving.
Contents of your file:
measure neckheight 1.000000
measure neckcirc 1.000000
But as already mentioned, it's values between 0 and 1.
Postby slspencer » Fri Feb 28, 2014 4:08 am
Duststorm, either the file isn't opening from the command line with
or it's opening the file but not adjusting the measure data
I can load it after MakeHuman opens & I select Files/Load.
When I changed weight to 1.0 & gender to 1.0 from the GUI then save it,
then tried to open the file from the command line,
MakeHuman still opens with the default character.
Do I have the command line wrong? Is there an option flag like this:
makehuman --file=NeckHeightNeckCircum.mhm
slspencer
