problem to install MakeHuman deb package
Re: problem to install MakeHuman deb package
Postby duststorm » Fri Oct 04, 2013 7:53 pm
bitacovir wrote:Before of this I had installed the nightly build of MH alpha 8, but the presentation of the model looks too artificial, like a clay statue and version alpha 7 is more natural and easy to identify the face features.
That is by design. The material shows the details of the model better, making it easier to model.
It will soon be possible to texture the model with better textures, but currently textures are still being created.
I found the texture in A7 often to be disturbing, scary even. The default texture was androgynous, but even then it did not fit well for females (in fact it didnt fit males either). Our conclusion is that it makes no sense having one texture to fit all.
In A8 we will have custom textures for different types of males and females that the user will be able to select after modeling the gender, age and ethnicity. It will look much better.
In any case, if you want to see the old texture back, you can select the "Textured" material from the material library.
