mhx2 not showing up in blender import 2.83lts
Postby VarnenskiqTuz » Sun Nov 15, 2020 6:33 pm
Hello, I'm a complete newbie with both Blender and Makehuman, but I have decided to learn new skills. I have installed blender 2.83 and makehuman 1.2.0. Also installed all 4 of the blender addons included in the installation archive file. Activated the addons, but still when I try to import a mhx2 file I just can't do it. It doesn't show on the import tab. Could anyone provide some tips on how to fix that? Thanks in advance.
VarnenskiqTuz
Re: mhx2 not showing up in blender import 2.83lts
Postby jwc » Mon Nov 16, 2020 5:44 am
Do you need to use MHX2 for some reason?
Using Blender with the MakeHuman plugins, it is now possible to directly import a model from MakeHuman 1.2.
This is done by starting MakeHuman, make sure the the Community/Socket tab has "Accept connections" selected, and the human model is configured as desired.
Then (with MakeHuman still running) select the "MakeHuman" tab in Blender (type n if the sidebar is not visible) and click "Import human"
The model will then be loaded into Blender .
If desired, the Settings tab has values that can be changed to meet specific requirements.
jwc
Postby VarnenskiqTuz » Mon Nov 16, 2020 7:43 am
Thanks, I will try to do that tonight and see what happens. I thought I needed mhx2 because on the tutorial I was watching that's what the guy was using.
VarnenskiqTuz
Postby tomcat » Mon Nov 16, 2020 4:18 pm
VarnenskiqTuz wrote:It doesn't show on the import tab.
mhx2 file is not on the import tab. Press "N" —> mhx2runtime
sorry for my bad english
