good forums guys i just made a custom hair fitted and exported using blender addon makeclothes its ok but when i try to put on hair at makehuman i got this error and hair didnt appear on my characters head
log:
Failed to load C:/Users/nanob/Documents/makehuman/v1/data/clothes/sidepart~0_default.001_default.001/sidepart~0_default.001_default.001.obj
Unable to load obj file: C:/Users/nanob/Documents/makehuman/v1/data/clothes/sidepart~0_default.001_default.001/sidepart~0_default.001_default.001.obj
File "core\files3d.py", line 206, in loadMesh
File "core\files3d.py", line 165, in loadTextMesh
File "shared\wavefront.py", line 148, in loadObjFile
File "core\module3d.py", line 642, in setFaces
File "core\module3d.py", line 712, in _update_faces
RuntimeError: Incompatible mesh topology.
Failed to load C:/Users/nanob/Documents/makehuman/v1/data/clothes/sidepart~0_default.001_default.000/sidepart~0_default.001_default.000.obj
do Change clothes
showing task Logs
Selecting proxy file "C:/Users/nanob/Documents/makehuman/v1/data/clothes\sidepart~0_default.001_default.000\sidepart~0_default.001_default.000.mhpxy" from clothes library.
compiled proxy file out of date: C:/Users/nanob/Documents/makehuman/v1/data/clothes\sidepart~0_default.001_default.000\sidepart~0_default.001_default.000.mhpxy
Problem loading binary proxy: ('compiled file out of date: %s', u'C:/Users/nanob/Documents/makehuman/v1/data/clothes\\sidepart~0_default.001_default.000\\sidepart~0_default.001_default.000.mhpxy')
Loading proxy file: C:/Users/nanob/Documents/makehuman/v1/data/clothes\sidepart~0_default.001_default.000\sidepart~0_default.001_default.000.mhclo.
Loading material from file C:/Users/nanob/Documents/makehuman/v1/data/clothes/sidepart~0_default.001_default.000/sidepart~0_default.001_default.000.mhmat
Compiling binary proxy file C:/Users/nanob/Documents/makehuman/v1/data/clothes\sidepart~0_default.001_default.000\sidepart~0_default.001_default.000.mhpxy
compiled file missing: C:/Users/nanob/Documents/makehuman/v1/data/clothes/sidepart~0_default.001_default.000/sidepart~0_default.001_default.000.npz
Problem loading binary mesh: ('compiled file missing: %s', u'C:/Users/nanob/Documents/makehuman/v1/data/clothes/sidepart~0_default.001_default.000/sidepart~0_default.001_default.000.npz')
Loading ASCII mesh C:/Users/nanob/Documents/makehuman/v1/data/clothes/sidepart~0_default.001_default.000/sidepart~0_default.001_default.000.obj.
Failed to index faces of mesh sidepart~0_default.001_default.000.obj, you are probably loading a mesh with mixed nb of verts per face (do not mix tris and quads). Or your mesh has too many faces attached to one vertex (the maximum is 8-poles). In the second case, either increase MAX_FACES for this mesh, or improve the mesh topology. Original error message: (<type 'exceptions.ValueError'>) could not broadcast input array from shape (9) into shape (8)
Unable to load obj file: C:/Users/nanob/Documents/makehuman/v1/data/clothes/sidepart~0_default.001_default.000/sidepart~0_default.001_default.000.obj
File "core\events3d.py", line 211, in callEvent
File "apps\gui\proxychooser.py", line 163, in onFileSelected
File "apps\gui\proxychooser.py", line 240, in proxyFileSelected
File "core\mhmain.py", line 858, in do
File "apps\gui\proxychooser.py", line 77, in do
File "apps\gui\proxychooser.py", line 308, in selectProxy
File "shared\proxy.py", line 166, in loadMeshAndObject
AttributeError: 'bool' object has no attribute 'priority'
hiding category Geometries
showing category Utilities
hiding task Clothes
showing task Logs
