Blender MHX2 Error
Blender MHX2 Error
Postby Antiqua_Sphinge » Mon Jun 26, 2017 2:16 am
I was able to get MakeHuman modified to export as MHX2 for import into Blender.
I added everything in the 3rd-party file to modify Blender to import MHX2 files, but I got the following error.
Any ideas on how to fix it would be appreciated.
Antiqua_Sphinge
Re: Blender MHX2 Error
Postby RobBaer » Mon Jun 26, 2017 4:34 am
When you installed .mhx2 blender component, did you drop the whole folder in the Blender addons directory (correct) or did you maybe drop the individual components from this folder in the Blender Addons folder (wrong)? It should also work to install from file in, user prefs but I have had this not work when the folder isn't a zipped archive.
It looks like maybe the .mhx2 install went wrong on the Blender side although I can't tell for sure.
Postby Antiqua_Sphinge » Mon Jun 26, 2017 12:21 pm
I dropped the entire folder into the Blender addons, and I also tried to install from file.
It turns out the issue was with the MHX2 zip file I originally downloaded from Thomas Larsson's site. When I tried it with the blender plugins (maketarget, makeclothes, makewalk and MHX2) zip file from this site it worked, though I'll have to load the target, clothes, and walk modules then set the correct permissions.
At least I got the MHX2 import working.
Thank you for trying.
And the 3.5-year-old appears to have awakened, meaning my duty day has picked back up. I need a nap.
Antiqua_Sphinge
