Downloaded proxy isn't loading?
Postby tyridge77 » Tue May 16, 2017 11:13 am
Hey guys, I'm new here. I tried downloading this very low poly proxy
http://www.makehumancommunity.org/proxy ... _poly.html
but when I click on it under topologies with makehuman, nothing happens and I get this error.
This is my file setup
What am I doing wrong?
Thank you
tyridge77
Re: Downloaded proxy isn't loading?
Postby Aranuvir » Tue May 16, 2017 5:49 pm
Please copy the whole error message: go to Utilities > Logs, set Level to 'Warning', click on the error message, then 'copy to clippboard'. Paste the clippboard content to the forum (best with code tags).
Postby tyridge77 » Tue May 16, 2017 7:45 pm
Aranuvir wrote:Please copy the whole error message: go to Utilities > Logs, set Level to 'Warning', click on the error message, then 'copy to clippboard'. Paste the clippboard content to the forum (best with code tags).
Sorry,
https://pastebin.com/K9H55bxz
tyridge77
Postby tyridge77 » Tue May 16, 2017 11:11 pm
Tried reinstalling MH, getting this still.
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\events3d", line 212, in callEvent
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\proxychooser", line 155, in onFileSelected
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\proxychooser", line 216, in proxyFileSelected
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\mhmain", line 760, in do
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\proxychooser", line 61, in do
  File "plugins/3_libraries_proxy_chooser.py", line 145, in selectProxy
    mesh,obj = pxy.loadMeshAndObject(self.human)
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\proxy", line 174, in loadMeshAndObject
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\files3d", line 180, in loadMesh
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\ntpath", line 198, in basename
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\ntpath", line 170, in split
  File "c:\jenkins\workspace\Windows_release\buildscripts\win32\build\makehuman\out00-PYZ.pyz\ntpath", line 125, in splitdrive
TypeError: 'NoneType' object has no attribute '__getitem__'
Proxy file data/proxymeshes\VeryLowPoly\VeryLowPoly.proxy does not specify a Z depth. Using 50.
Unknown keyword use_projection found in proxy file data/eyes/high-poly/high-poly.mhclo
shortcuts.ini out of date; ignoring
tyridge77
Postby tyridge77 » Wed May 17, 2017 12:57 am
I'd appreciate if someone could help me with this..
tyridge77
Postby tyridge77 » Wed May 17, 2017 2:54 am
So, strangely enough, the issue was that I was saving the proxy files off the edge browser.
After switching to chrome things worked out fine..
perhaps edge wasn't copying all the text?
tyridge77
Postby loki1950 » Wed May 17, 2017 3:20 am
Edge was saving as .html not text so it failed because the file was in the wrong format both Edge and Apple's Safari are guilty of this it boils down to the fact that both Apple and Microsoft assume you are a dummy who has no need of anything other than .html in a web browser and of course paranoia about malware :twisted:
Postby Aranuvir » Wed May 17, 2017 7:06 am
loki1950 wrote:Edge was saving as .html [...]
At first I had the same in mind. But the file explorer screen shot seems to indicate correct file types, at least not html (and IIRC Windows only recognises file types by extension). And further more, when I rename all files, the proxy simply won't show up, and when renaming parts of it I get completely different error messages...
@OP: "shortcuts.ini out of date; ignoring", "Unknown keyword use_projection found in proxy file data/eyes/high-poly/high-poly.mhclo": What version of MH are you using? Can you provide a log file?
