Head measurement
Head measurement
Postby Paintstar » Fri Dec 16, 2016 9:54 pm
Hi there, new user here.
I found the ''measurements'' tab and all the available options but the measurement stops at the neck.
Is there any way i can make measurable changes on the head ? like the perimeter, the cheek to cheek distance, etc.
I want to use it as base to build movie helmets but i need to have the exact measures.
Thanks in advance.
Paintstar
Re: Head measurement
Postby loki1950 » Sat Dec 17, 2016 4:28 am
The measurements are derived from the base mesh mathematically but there is no direct correlation between slider positions as they are only values between 0 and 1 it is theoretically possible to do the measurements but it would require a few months of research apart from the coding as the morphs are parametric based on a data base of real world scans from all over the world.The Valintina(not write spelling) project which is a fashion design tool may have such capabilities but I doubt it as they use a fashion industry standard set of measurements hat size may be one but cheek to cheek likely not.Sorry to disappoint you.We have been asked several times why you can't just input a series of values and the reason is that MH is parametric not deterministic.
Postby Paintstar » Sat Dec 17, 2016 9:45 am
Thanks for the reply!
I guess i'll figure a way ;)
Paintstar
