download_assets.py failure
Postby Flix » Wed Feb 24, 2016 3:19 pm
Hi.
I use the hg version of MakeHuman.
On my last "hg pull/hg update" the version switched to 1.2.
It works, except that when I try running: python download_assets.py, I get:
Refreshing assets from repository "base" (version 1.2)
Connecting to FTP...
  File "download_assets.py", line 311, in <module>
    ftp.cwd(ftpPath.replace('\\', '/'))
  File "/usr/lib/python2.7/ftplib.py", line 562, in cwd
    return self.voidcmd(cmd)
  File "/usr/lib/python2.7/ftplib.py", line 254, in voidcmd
    return self.voidresp()
  File "/usr/lib/python2.7/ftplib.py", line 229, in voidresp
    resp = self.getresp()
  File "/usr/lib/python2.7/ftplib.py", line 224, in getresp
    raise error_perm, resp
ftplib.error_perm: 550 Can't change directory to /makehuman/assets/1.2/base: No such file or directory
When am I supposed to create the /makehuman/assets/1.2/base folder ? In the root folder of my Linux system ?
Please help. Thank you in advance.
Flix
Re: download_assets.py failure
Postby joepal » Wed Feb 24, 2016 3:42 pm
Yes, as noted in numerous posts upon the topic: There are no assets for 1.2 yet.
Currently, the best suggestion is to use the "stable" branch from bitbucket, which contains what is to become 1.1.0. What is now the "default" branch (i.e 1.2.x) only contain experiments so far.
If you still want to run the default branch (it'll break in other ways too), see this post for hints: viewtopic.php?f=6&t=13169
Postby Flix » Wed Feb 24, 2016 6:10 pm
Thanks for your answer.
Flix
