What version of MH contains the face rigs?
Postby efreet » Wed Jul 09, 2014 3:58 pm
I just saw this cool video at https://www.youtube.com/watch?v=mtycWqkvHeo
Has this become available already? If not yet for stable release, which version should I get?
Thank you in advance
Also, does anyone know about plans to add Shape Keys on face rigs?
Thanks
efreet
Re: What version of MH contains the face rigs?
Postby duststorm » Thu Jul 10, 2014 1:29 am
The new rigging fork contains the code for the new rigs, but it's unstable and prone to sudden change, which is why it is not yet included in the official unstable branch. You can find it in the rigging subproject on the issue tracker.
But it is source code, there is no binary build of it, so you will need to be able to run the source code.
Postby efreet » Thu Jul 10, 2014 3:17 pm
Thank you for replying duststorm and for developing MakeHuman :)
I still would like to try the unstable version, but I don't see a branch named rigging or unstable. (all branches I can see are 'default' and 'stable') Is there some restriction, Or maybe I'm just lost because I'm not familiar with bitbucket. If there isn't a restriction, can someone please send me a link to where I can get the source code for rigging?
Also, to compile it, what libraries would I need?
Lastly just to confirm, is there no foreseeble plan to add blendershape (Shape Keys)?
efreet
Postby duststorm » Thu Jul 10, 2014 5:46 pm
efreet wrote:I don't see a branch named rigging or unstable
I meant "fork"
Look in the issue tracker to have an overview of the entire project.
efreet wrote:Lastly just to confirm, is there no foreseeble plan to add blendershape (Shape Keys)?
The face rig poses can be converted to blendshapes, if you require this in your pipeline.
But you will not get more quality from this.
I would generally use blendshapes to get that extra bit of detail, detail that is so specific to your mesh that it cannot be generically auto modeled. Like small wrinkles and skin effects.
Postby efreet » Thu Jul 10, 2014 7:02 pm
Duststorm,
Did you mean https://bitbucket.org/MakeHuman/makehum ... ig-staging? I don't think I have access to MH's issue tracker (is it Jira, same Atlassian?), so I just searched for 'rigging' in the "owner/repository" and it was 17th on the list. (there was also https://bitbucket.org/MakeHuman/makehuman-rigging to add to confusion) Anyway, thank you.
EDIT: Actually, the issue tracker is here -> http://bugtracker.makehuman.org/projects/makehuman
For my pipeline, btw, I'll just convert to blendshapes manually as you advised. Expert tips are helpful.
efreet
Postby efreet » Thu Jul 10, 2014 9:14 pm
I also found another video of MakeHuman that used face rigs, but this one is old. https://www.youtube.com/watch?v=IczhdEDg-ok
Did this face rig become obsolete because of the new one, or am I just doing something wrong? I don't see the face bones or MHX Expression or MHX LipSync menus in my model, like in this video.
efreet
Postby duststorm » Thu Jul 10, 2014 9:52 pm
Either that one or the one on Thomas' bitbucket account, yes.
efreet wrote:Actually, the issue tracker is here -> http://bugtracker.makehuman.org/projects/makehuman
Exactly
efreet wrote:For my pipeline, btw, I'll just convert to blendshapes manually as you advised. Expert tips are helpful.
I believe the new MHX importer tools already have the buttons for that.
Postby efreet » Fri Jul 11, 2014 3:36 pm
Ok, so to summarize
Forks with face rig in it:
https://bitbucket.org/MakeHuman/makehuman-newrig-staging
https://bitbucket.org/ThomasMakeHuman/newrig
https://bitbucket.org/MakeHuman/makehuman-rigging <<-- not being worked on
Issue Tracker:
Dustorm, can you answer my next question?
efreet wrote:I also found another video of MakeHuman that used face rigs, but this one is old. https://www.youtube.com/watch?v=IczhdEDg-ok
and thanks for the tip on the MHX importer. I didn't know it existed. I'll look. This will save me a lot of time.
efreet
Postby duststorm » Sun Jul 13, 2014 11:19 pm
That video is the A7 mesh (HM07), so yes, it's of an old version of MakeHuman.
We are working on a new and better rig, with better expressions that actually fit all head types that MakeHuman produces.
Users browsing this forum: No registered users and 17 guests
