ngc7293 wrote:Thanks for the information about the Particle system only Node.
About the Lokis node setup. Here is what it it looks like with lashes:
The picture is really small. Do the eyelashes show semi-transparent areas instead of being fully transparent? Then the result of the shader you presented is weird, because on my box it is working. But blender has other possibilities to generate this problem
The other problem is, that a semi-transparent area with glossiness works like a mirror ... so for the hair you should change the setup like Aranuvir is doing. E.g. for the eyelashes only the diffuse and transparent shader without Fresnel and glossy shader are sufficient, at least I simplified my setup to this very basic method.
