Problems...
Problems...
Postby Kerol87 » Thu Sep 22, 2011 7:24 am
I just installed MakeHuman 1.0 alpha6 on my WinXP 32bit laptop.
This message appears on ms-dos prompt when i run the software:
'import site' failed; use -v for traceback
Version 1.0.0
Color 0 ([0, 0, 0]) not found
not a clickable zone
Could not load data/themes/default/images/radial_graph.png, Couldn't open data/t
Asymmetry loaded
Face imported
Face loaded
File "main.py", line 274, in loadNextPlugin
module = imp.load_source(name, path)
File "plugins\0_modeling_hair_properties.py", line 5, in <module>
import colorsys
ImportError: No module named colorsys
Could not load 0_modeling_hair_properties
Measurement loaded
Random imported
Ethnics imported
BVH Player loaded
Expression imported
Expression loaded
Pose2 plugin imported
pose loaded
Skeleton loaded
Background chooser loaded
Hair chooser loaded
Texture chooser loaded
POV-Ray Export Parameter File
povray imported
Povray loaded
Rendering setting imported
Settings imported
Shortcuts imported
Help imported
makehair plugin
Storing mesh status
Pose plugin imported
pose loaded
Unable to open data/targets/macrodetails/universal-male-young.target
Unable to open data/targets/macrodetails/universal-female-young.target
Is it has anything to do with the Aqsis software? I did installed it but nothing changed. How to use it?
The MakeHuman software works but i feel that something missing.
Any solution?
Thanks...
Kerol87
Re: Problems...
Postby Manuel » Thu Sep 22, 2011 1:14 pm
Hi Kerol, welcome.
Don't worry, the messages are ok. It happen because it's an alpha version.
Best,
