Thomas_Ray wrote:... but the hair and clothing have these orange stripes on them---as if the texture file is not working. What's wrong and how do I fix it?---Thanks for the help.
loki1950 wrote:It most likely is an issue with the path line in the .mhmat files as that is the file that defines materials(textures) where have you put the files you downloaded they should be at "Documents\makehuman\v1\data\clothes each piece of clothing/hair in it's own folder with the appropriate name the full workflow can be found here http://www.makehumancommunity.org/wiki/ ... ll_them%3F if you have further problems please post and we will hopefully be able to help.Enjoy the Choice
Aranuvir wrote:Did you download the image textures, too? Normally an asset consists of a mhclo, obj, mhmat, thumb and one or more image textures. So, usually at least 5 files. All these files should go into the same folder.
