Default textures not working
Postby jon4th4nirreno » Sat Nov 12, 2016 11:57 pm
I tried working on makehuman again, I had used it before, but i uninstalled because I didn't use it.
I re-installed the latest version (from the official links) and tried changing the default skin texture, and i find this problem:
the textures seem to be not working, I checked the folders, and the files are there, but it doesn't work.
the clothes' textures are also not showing.
I already re-downloaded and it still doesn't work
jon4th4nirreno
Re: Default textures not working
Postby loki1950 » Sun Nov 13, 2016 2:11 am
Looks like you have an Intel GPU most do not fully support OpenGL here is a work around http://www.makehumancommunity.org/wiki/ ... help_me%3F it's the second question in our FAQ ;)
Postby FierceSavitar » Sat Dec 17, 2016 4:45 pm
To make it work, use a text editor like wordpad, notepad or any coding text editor and right click it, after that in a pop-up menu in windows, it should say somewhere edit with notepad++ or notepad depending on you text editor. Next your going to want to look at a certain line that has the text "diffuseTexture and you'll see a directory where you should be able to change it from /textures/ to /skins/. Then your done. But if you have a folder named textures don't bother.
FierceSavitar
Users browsing this forum: Google [Bot] and 3 guests
