No teeth or eyebrows available
Postby turion » Wed Feb 24, 2016 10:11 am
The "teeth" directory in "data" is completely empty and there are no selection options when I go to "Geometries -> Teeth". But looking at models created by other people it seems like there are teeth assets around, I just can't find them! Same goes for eyebrows and eyelids.
I'm running v1.2.0 on Gentoo Linux.
turion
Re: No teeth or eyebrows available
Postby joepal » Wed Feb 24, 2016 11:30 am
This is because the asset downloading routines haven't been updated to find any assets for 1.2 yet.
My primary recommendation would be to switch to the "stable" branch instead of "default" when you run from source. Default was merged into stable only a few weeks in preparation for 1.1.0, and the changes since are marginal. In stable the download_assets.py script works.
If you want to test something specifically in 1.2.0 (only thing I can think of is the not-yet-perfectly-working makeclothes and fitting stuff), you can download the assets by cloning this repo: https://github.com/makehumancommunity/o ... assets_11x and then copy everything under base so that it resides under data in the makehuman directory.
Postby turion » Wed Feb 24, 2016 12:03 pm
Thanks, I installed 1.1.0 and found lots of teeth, eyebrows etc.!
turion
