Face UV and Topology
Postby mdmoberly » Thu Jun 26, 2014 8:56 pm
Hello, all!! new to MH and had a few questions, which, I'm sure has been asked here.. ..I just cannot find any posts.
So basically, I would like to be able to either import a head mesh to MH before exporting to Blender, or edit the mesh inside blender with the new head mesh.
However, I would like to use the UV from MH, but with the new unwrapped face..
not sure if I am wording it correctly, but I would basically like to be able to use something like Faceworks or FaceGen in combination with blender and makehuman. Is this possible? and if so, is there a tut already floating around that I was unable to retrieve via Google..?
Any insight would be wonderful!
Thanks!
Matthew
mdmoberly
Re: Face UV and Topology
Postby mdmoberly » Thu Jun 26, 2014 9:25 pm
I decided to search the forums for "FaceGen" and turned over a few stones I didn't see before. I found this: http://forum.makehuman.org/viewtopic.php?f=4&t=8752&p=19002&hilit=facegen#p19961
This is the only way of doing what I mentioned..? Correct me if I am wrong! As before, any information would be greatly appreciated!
Thanks,
Matthew
mdmoberly
Postby duststorm » Sat Jun 28, 2014 3:13 pm
You can do it in blender. Export both meshes (from MH and from facegen) to Blender, and use the MakeClothes plugin in Blender.
MakeClothes has tools for fitting a new mesh (eg a head) to the basemesh, and transferring seams and UV maps.
You could use those.
