Export from Blender to MakeClothes (Blender extension)
Re: Export from Blender to MakeClothes (Blender extension)
Postby thexp » Fri Dec 13, 2013 10:11 pm
Now I'm getting this error: Image
Sorry for all your trouble.
thexp
Postby duststorm » Sat Dec 14, 2013 12:53 am
Exactly what it says. It thinks that the clothes, or whatever you are trying to fit against the human, are too far away from the human to get a good result. It refuses to match it.
Try modeling your proxies closer to the body, or vertex group it to geometry closer by your model.
If this is not an option to you and you want to persist in matching, you'll have to modify the MakeClothes script.
What model were you trying to run through makeclothes?
Postby thexp » Sat Dec 14, 2013 1:46 am
I've exported an mxh from makehuman with a human with the basic costume clothing item on. I then modified the shirt and added it in to another blender file and i'm trying to run the shirt through makeclothes.
thexp
Postby duststorm » Sat Dec 14, 2013 3:53 pm
If it is a regular fitting shirt then it should work.
Check your vertex groups, you're probably attempting something like fitting the shirt to the legs only.
Thomas: what does the "check human and clothes scales" message mean? From what I could test, MakeClothes takes into account object scales, so that's probably not what it means.
Postby thexp » Sat Dec 14, 2013 10:55 pm
Okay. I've successfully made it, but now when I try to apply it to the character in MakeHuman (I'm using 1.0 Alpha 7), It appears in Libraries -> Clothes, but when i click on it it just does nothing. The preview for the clothe is also a "?".
thexp
Postby ThomasL » Sun Dec 15, 2013 3:19 pm
The version of MakeClothes in svn does not work with alpha 7. The MH mesh is totally different between the two versions.
ThomasL
Postby thexp » Sun Dec 15, 2013 10:55 pm
Ok. Where can I download a precompiled installer? Or do I have to compile it myself?
thexp
Postby duststorm » Mon Dec 16, 2013 12:59 am
All MH code is python, so it does not need to be compiled. You can find the latest version in the svn. Or you can download a nightly packaged zip file from the website.
Postby thexp » Mon Dec 16, 2013 1:40 am
Awesome. Thanks so much. are the nightly builds semi-stable?
thexp
Postby duststorm » Mon Dec 16, 2013 1:14 pm
thexp wrote:are the nightly builds semi-stable?
Yes, since we are nearing a release.
