Nightly Build standard pose
Postby 3DNewb » Fri Oct 18, 2013 6:29 am
Hey all,
I love the nightly build, but I'm have trouble changing the pose of the model to the standard "T" pose that is default in Alpha 7 from the slightly crouching pose that is standard in the nightly build. When I try to switch to the "standard" pose out of the options, it remains the same. Any thoughts?
Attached is the default nightly build pose I'm referring to, which I would like to change to the T pose.
Thanks!
3DNewb
Re: Nightly Build standard pose
Postby duststorm » Fri Oct 18, 2013 2:09 pm
The mesh bind pose is the A-pose you see in that image. Which means that the mesh was modeled in this pose and consequently bound to a skeleton in that same pose.
It's possible to make the human pose in T-stance if you export a rigged character (not OBJ format but something like MHX, DAE or FBX) and reverse-pose the bones to get it in T stance.
It's possible that there is a feature in the blender scripts to move the character in T-pose, Thomas might know more. I know that the Mocap scripts retarget BVH files to the rig by first correcting the rig pose so that it matches a T rest pose, and then apply the rotations of the captured motions. So the data is already present there, I believe in the .src or .trg rig mapping files.
Postby Manuel » Fri Oct 18, 2013 2:13 pm
We will also add a static T-pose later, so it will be very easy to convert it.
Postby duststorm » Fri Oct 18, 2013 2:16 pm
Manuel wrote:We will also add a static T-pose later, so it will be very easy to convert it.
Yes indeed, that would be a very cool feature.
We probably can do both. Convert the static geometry to a T-pose and export it to a static mesh format, and convert the rest pose of the skeleton to the posed one, and export a T-posed mesh to rigged formats as well.
Postby AqP » Fri Nov 15, 2013 9:13 pm
I'd also like a T pose. It's confusing that some of the MH documentation says that T Pose is standard.
AqP
Postby duststorm » Fri Nov 15, 2013 11:10 pm
AqP wrote:It's confusing that some of the MH documentation says that T Pose is standard.
Most of the documentation is outdated and needs rewriting.
