Where are the textures?
Postby uncle808us » Sun Mar 16, 2014 3:19 pm
I just downloaded 1.0.0 for Mac and exported a figure out as an FBX. Everything went fine rig geometry etc. but no textures. Where are the textures?
There is a texture folder but it is empty. Thanks
OSX El Capitan
Ver 10.11.6
uncle808us
Re: Where are the textures?
Postby duststorm » Sun Mar 16, 2014 8:34 pm
This is a known bug and in the latest release.
Are you certain you are using the latest download?
Postby uncle808us » Mon Mar 17, 2014 12:53 am
duststorm wrote:This is a known bug and in the latest release.
I don't know I got it here: http://www.makehuman.org/content/downlo ... n_100.html
OSX El Capitan
Ver 10.11.6
uncle808us
Postby duststorm » Mon Mar 17, 2014 1:01 am
That version should work fine.
In your exports folder (the folder where your fbx file is) should be a folder called "textures". It should contain all the textures of your model.
For the default human, that is only the brown eye texture. If you add textured materials, for example when adding clothes to the mesh or setting a textured skin material, there will be more textures in that folder when you export.
Some tools that import FBX require you to reference and import the textures manually.
Postby uncle808us » Mon Mar 17, 2014 2:36 am
I got it working. Not sure what I did, But That's sounds about right for me. Thanks for your help.
OSX El Capitan
Ver 10.11.6
uncle808us
Postby Roygee » Mon Mar 17, 2014 6:19 am
I am using 1.0.0-Win32 - have exported several figures in .obj, .fbx and .dae, using different materials and my texture folder is still empty. Any advice?
Roygee
Postby duststorm » Mon Mar 17, 2014 3:59 pm
Roygee wrote:I am using 1.0.0-Win32 - have exported several figures in .obj, .fbx and .dae, using different materials and my texture folder is still empty. Any advice?
Could you attach logfiles after attempting such an export to this thread?
Postby uncle808us » Mon Mar 17, 2014 4:09 pm
Don't know whither this will be of help but I went thru each material to be exported hair etc. and clicked on each material. In Material.This worked for me Mac 10.9.2
hope this helps.
OSX El Capitan
Ver 10.11.6
uncle808us
Postby uncle808us » Thu Mar 20, 2014 2:33 pm
Here's your answer: The missing texture was a bug, which should now fixed in the default branch. It happened when the mesh was exported with units other than decimeters.
Use decimeters.
OSX El Capitan
Ver 10.11.6
uncle808us
Postby duststorm » Thu Mar 20, 2014 4:50 pm
It will be fixed in the 1.0.1 bugfix release. Probably in 2 weeks or so.
