Therefor I want to define some local shortcuts, by means of
lib/qtui.py 750 pp¹
- Code: Select all
def setShortcut(modifier, key, action):
action.setShortcut(QtGui.QKeySequence(modifier + key))
which is passed upwards by the mh module.
Thus I have to define "actions" by means of mh's framework, and parent them to a local group, which is itself parented to the Scripting widget.
The gui (i.e. qtgui passed through) adapter exposes a group parameter, which offers means for such custom parenting of actions
lib/qtgui.py 1858 pp²
- Code: Select all
class Action(QtGui.QAction, Widget):
def __init__(self, name, text, method, tooltip = None, group = None, toggle = False):
super(Action, self).__init__(self.getIcon(name), text, G.app.mainwin)
self.name = name
self.method = method
if tooltip is not None:
self.setToolTip(tooltip)
if group is not None:
self.setActionGroup(self.getGroup(group))
if toggle:
self.setCheckable(True)
self.connect(self, QtCore.SIGNAL('triggered(bool)'), self._activate)
def setActionGroup(self, group):
super(Action, self).setActionGroup(group)
but unfortunately the ActionGroup model exposed by the framework itself gets always parented to main win.
lib/qtgui.py 1916 pp³
- Code: Select all
class ActionGroup(QtGui.QActionGroup):
def __init__(self):
super(ActionGroup, self).__init__(G.app.mainwin)
Of course, I could add an optional parameter to the ActionGroup ctor, but I'd rather not change an interface in a central layer of mh just for tiny task in a plugin.
Are there other means the mh's framework offers for defining local shortcuts than the one I sketched?
¹ https://bitbucket.org/MakeHuman/makehum ... ult#cl-750
² https://bitbucket.org/MakeHuman/makehum ... lt#cl-1858
³ https://bitbucket.org/MakeHuman/makehum ... lt#cl-1916
