Unity 3d Rig
Unity 3d Rig
Postby bobbylee » Sun Sep 21, 2014 12:36 am
Hello, I am not sure how many people here use Unity 3D, but I came across this rig for Mechanim on a website and tested it out, all I do is use this rig, export as fbx, bring it in to Unity and set T-Pose and use Autorig and all works really well. I am seeing no strange things as I do with the other rigs. I have applied many Mechanim animations to a few models and love the results.
see attached, rar of unity3d.json , extract, drop in MH folder data/rigs and it will show up in your MH choices.
Credit to who ever put this together.
unity3d.rar
Unity rig
(813 Bytes) Downloaded 819 times
bobbylee
Re: Unity 3d Rig
Postby Manuel » Sun Sep 21, 2014 8:50 am
Hi Bobblylee,
thank you. Is this the same issue as http://bugtracker.makehuman.org/issues/95 ?
Re: Unity 3d Rig
Postby bobbylee » Sun Sep 21, 2014 2:45 pm
Not the same rig as linked to there, but addresses that first point.
This rig has all the bones that Unity Mechanim looks for in a humanoid, then it is easy to apply mocap's in Unity using Mechanim.
All the others I tried had weird distortions, the best one still had fingers pointing weird.
You never need to go to Blender to animate as you can do it all in Mechanim, as long as you have mocap locomotion data, you can transfer it to your new model.
Export: Choose this Unity rig, feet on ground, fbx, centimeter(works best for me).
Unity Import: Select Humanoid and apply, choose Rig tab, enforce T=Pose and apply, Mapping-Automap, apply.
Note: I have been using the latest Unity 4.5 releases, but I do not expect rig changes until maybe Unity 5 comes out, not sure on that yet.
bobbylee
Re: Unity 3d Rig
Postby Manuel » Sun Sep 21, 2014 4:55 pm
bobbylee wrote:Not the same rig as linked to there, but addresses that first point.
Thank you.
Is your rigging better than the one linked in the issue tracker? In that case we will use it officially in MH1.1
(Note: the skeleton format will be different in MH1.1)
Re: Unity 3d Rig
Postby duststorm » Sun Sep 21, 2014 6:22 pm
Nice work!
Thank you for sharing it. We'll definitely take a look at it while handling the rigs to include in the new version. We want to have at least one rig that works with Unity out of the box.
Re: Unity 3d Rig
Postby bobbylee » Sun Sep 21, 2014 7:28 pm
Manuel wrote:Thank you.
The rig I uploaded is for model export by fbx directly into Unity, that other one is a Blender rig.
I guess it would be good for people to have an option, (Unity Blender, Unity Direct)?
I need to know more about the MH1.1 skeleton format to know if this is easily converted for that.
I do not mind trying to convert it when the time comes.
bobbylee
Re: Unity 3d Rig
Postby Manuel » Sun Sep 21, 2014 7:55 pm
As "rigging" I mean the number of bones, their positions, their names, their roll angles and the way they are parented.
No matter if this skeleton description is from a Blender file or from an fbx, we will get this base structure and then we will elaborate it in order to make an item for MH library.
When the skeleton will be in MH library, it will be exportable in all formats available (fbx, dae, skel, etc..).
So I was asking if your skeleton structure is more flexible and compatible than the one in the Blender file posted in the issue.
We will document is as soon as it will be ready and well tested, thank you.
Re: Unity 3d Rig
Postby bobbylee » Mon Sep 22, 2014 1:17 am
Got you, was not thinking of it in that way as handled by MH, feel dumb :), anyway I did try the Blender file one and found a few similar issues using it, hopefully your testing will lead to a good outcome.
Thanks.
bobbylee
Re: Unity 3d Rig
Postby aaronbooth » Tue Sep 23, 2014 3:24 pm
That's great, saves me having to reassign the fingers on the game rig. Cheers for that :)
I am thinking when the expressions are back to use them will require a special rig?
aaronbooth
Re: Unity 3d Rig
Postby Manuel » Tue Sep 23, 2014 3:27 pm
aaronbooth wrote:I am thinking when the expressions are back to use them will require a special rig?
Yes..since there is not a standard in face rigging, any facial rigging is special.
This is the kind of rigging (this is an old version) we are working on: http://vimeo.com/97096194
