Windows 7 64-bit
Windows 7 64-bit
Postby amunra777 » Mon Mar 17, 2014 11:15 am
Hi, great program. But I was disappointed when I did not start on Windows 7 64 bit. When will a version for Windows 7 64-bit?
amunra777
Re: Windows 7 64-bit
Postby Manuel » Mon Mar 17, 2014 11:38 am
We extensively tested it on Windows 7 and 8.
Can you describe exactly the problem?
Postby amunra777 » Mon Mar 17, 2014 12:23 pm
Manuel wrote:We extensively tested it on Windows 7 and 8.
Sorry I made a mistake, Windows 8 64-bit
не Does not start, error ddl
amunra777
Postby amunra777 » Mon Mar 17, 2014 1:50 pm
I started up after I moved the program on disk D:\
This is due to the fact that the program could not read Russian font folder path on an Russian
amunra777
Postby Manuel » Mon Mar 17, 2014 2:10 pm
amunra777 wrote:I started up after I moved the program on disk D:\
Uhm...thank you, we have not tested on win 8 with special characters.
In theory the dll should use a relative path, not an absolute one.
I'll point the programmers to this thread...
Postby Manuel » Mon Mar 17, 2014 3:23 pm
I created an issue for this.
http://bugtracker.makehuman.org/issues/230
Postby duststorm » Mon Mar 17, 2014 3:32 pm
What happens if you move it to D:\makehuman (with no special characters in the path)?
Does it work then?
This is a pyinstaller packaging issue, it's not a bug in MH directly.
I'll look around if I can find a solution.
Postby amunra777 » Mon Mar 17, 2014 8:25 pm
duststorm wrote:What happens if you move it to D:\makehuman (with no special characters in the path)?
Does it work then?
Previously, he was in a folder D:\Загрузки\makehuman and he did not run
Then I moved D:\makehuman and he has started
amunra777
Postby duststorm » Tue Mar 18, 2014 12:40 am
amunra777 wrote:Previously, he was in a folder D:\Загрузки\makehuman and he did not run
So that's cleared out. It has nothing to do with different drive letters, but the pyinstaller packages cannot find packed DLLs in paths with non-ascii (or different codetable?) characters.
Perhaps this should be reported on the pyinstaller issue tracker directly.
Postby Potimarino » Sun Aug 19, 2018 7:08 pm
amunra777 wrote:Hi, great program. But I was disappointed when I did not start on Windows 7 64 bit. When will a version for Windows 7 64-bit?
Potimarino
