Ubuntu 64 bit makehuman alfa 2
Postby tyyppijkl » Tue May 19, 2009 2:14 pm
Well,
At least I have problem with this version. If I want change example nose, scale something with mouse, it does not work. In console I can see than python does not like property dy. Mouse control fill area to red, but not change anything.
Everything else works, example change age.
Pre release version woks okey, but alpha versions went bad in some point.
Any Idea of this.
And one issue: 64 bit building is very soon more asked than 32 bit building.
tyyppijkl
Re: Ubuntu 64 bit makehuman alfa 2
Postby joepal » Tue May 19, 2009 4:48 pm
Do the 32-bit nightly builds at http://mh.jwp.se work on your box?
Postby ezteban » Wed May 20, 2009 6:24 am
Hello,
i just compiled rev. 131 on opensuse 11.1.
If i try to move or scale a bodypart, i only get lots of these errors on the console:
  File "./mh_core/module3d.py", line 1284, in mouseMotion
    self.application.mouseMove(mouseState, x, y, xRel, yRel)
  File "./mh_core/gui3d.py", line 400, in mouseMove
    self.mouseDownObject.callEvent("onMouseDragged", event)
  File "./mh_core/events3d.py", line 47, in callEvent
    getattr(self, eventType)(event)
  File "main.py", line 120, in onMouseDragged
    self.tool.callEvent("onMouseDragged", event)
  File "./mh_plugins/guidetailmodelling.py", line 223, in onMouseDragged
    d = event.dy
AttributeError: MouseEvent instance has no attribute 'dy'
greetings
ezteban
ezteban
Postby mkeyl » Thu May 21, 2009 4:05 pm
I was able to solve the problem with the following simple patch (against rev. 131):
--- mh_core/events3d.py.orig    2009-05-19 14:16:42.000000000 +0000
+++ mh_core/events3d.py 2009-05-21 15:35:14.000000000 +0000
@@ -10,6 +10,8 @@
     self.button = button
     self.x = x
     self.y = y
+    self.dx = dx
+    self.dy = dy
   def __repr__(self):
     return "event: %s, %s, %s, %s, %s" %(self.button, self.x, self.y, self.dx, self.dy)
The nightly build does not work for me because its linked against python 2.5 while I am using 2.6.
mkeyl
Postby ezteban » Sun May 24, 2009 8:41 am
Thanks, it works with your patch!
greetings
ezteban
ezteban
Postby Manuel » Thu May 28, 2009 8:42 am
Fixed in svn also.
Thanks,
