freeglut breaks at startup
Postby m.e » Fri Jul 25, 2008 9:13 am
I am getting the following when I start makehuman:
~> makehuman
freeglut (makehuman):  ERROR:  Internal error <Visual with necessary capabilities not found> in function fgOpenWindow
X Error of failed request:  BadWindow (invalid Window parameter)
  Major opcode of failed request:  4 (X_DestroyWindow)
  Resource id in failed request:  0x0
  Serial number of failed request:  20
  Current serial number in output stream:  20
makehuman used to work on my system, but I have not used it for several months, so something might have changed.
glxgears works, so presumably I have glx working. I am not sure what else I can do to check.
m.e
Re: freeglut breaks at startup
Postby m.e » Fri Jul 25, 2008 9:51 am
I have checked the code, which reads:
..../mhgui-0.2/src/CGUtilities.cpp:420:  glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB | GLUT_DEPTH);
which I understand should be ok.
Here is the result of running glxinfo (the forum would not let me upload this as an attachment):
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
    GLX_EXT_texture_from_pixmap, GLX_ARB_multisample, GLX_NV_float_buffer,
    GLX_ARB_fbconfig_float
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
    GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
    GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_texture_from_pixmap,
    GLX_EXT_framebuffer_sRGB, GLX_NV_present_video
GLX version: 1.3
GLX extensions:
    GLX_ARB_fbconfig_float, GLX_ARB_get_proc_address
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 6200 TurboCache(TM)/PCI/SSE2
OpenGL version string: 2.1.2 NVIDIA 173.14.09
OpenGL extensions:
    GL_ARB_color_buffer_float, GL_ARB_depth_texture, GL_ARB_draw_buffers,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_fragment_shader, GL_ARB_half_float_pixel, GL_ARB_imaging,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_shadow, GL_ARB_shader_objects, GL_ARB_shading_language_100,
    GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_texture_float,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
    GL_ATI_texture_mirror_once, GL_S3_s3tc, GL_EXT_texture_env_add,
    GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_Cg_shader, GL_EXT_depth_bounds_test, GL_EXT_draw_range_elements,
    GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
    GL_EXT_framebuffer_object, GL_EXT_gpu_program_parameters,
    GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
    GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
    GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
    GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
    GL_EXT_texture_object, GL_EXT_texture_sRGB, GL_EXT_timer_query,
    GL_EXT_vertex_array, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_KTX_buffer_region, GL_NV_blend_square,
    GL_NV_copy_depth_to_color, GL_NV_depth_clamp, GL_NV_fence,
    GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_program,
    GL_NV_fragment_program_option, GL_NV_fragment_program2,
    GL_NV_framebuffer_multisample_coverage, GL_NV_half_float,
    GL_NV_light_max_exponent, GL_NV_multisample_filter_hint,
    GL_NV_occlusion_query, GL_NV_packed_depth_stencil, GL_NV_pixel_data_range,
    GL_NV_point_sprite, GL_NV_primitive_restart, GL_NV_register_combiners,
    GL_NV_register_combiners2, GL_NV_texgen_reflection,
    GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
    GL_NV_texture_expand_normal, GL_NV_texture_rectangle,
    GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
    GL_NV_vertex_array_range, GL_NV_vertex_array_range2, GL_NV_vertex_program,
    GL_NV_vertex_program1_1, GL_NV_vertex_program2,
    GL_NV_vertex_program2_option, GL_NV_vertex_program3,
    GL_NVX_conditional_render, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
    GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SUN_slice_accum
120 GLX Visuals
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x22 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x24 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x27 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x28 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x29 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x2a 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x2b 24 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x2c 24 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x2d 24 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x2e 24 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x2f 24 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x30 24 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x31 24 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x32 24 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x33 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x34 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x35 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x36 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x37 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x38 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x39 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x3a 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x3b 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x3c 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x3d 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x3e 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x3f 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x40 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x41 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x42 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x43 24 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x44 24 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x45 24 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x46 24 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x47 24 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x48 24 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x49 24 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x4a 24 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x4b 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x4c 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x4d 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x4e 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x4f 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x50 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x51 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x52 24 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x53 24 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x54 24 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x55 24 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x56 24 dc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x57 24 dc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x58 24 dc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x59 24 dc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x5a 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x5b 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x5c 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x5d 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x5e 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x5f 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x60 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x61 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x62 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x63 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x64 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x65 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x66 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x67 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x68 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x69 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x6a 24 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x6b 24 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x6c 24 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x6d 24 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x6e 24 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x6f 24 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x70 24 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x71 24 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x23 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x72 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x73 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x74 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x75 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x76 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x77 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x78 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x79 32 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x7a 32 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x7b 32 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x7c 32 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x7d 32 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x7e 32 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x7f 32 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x80 32 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x81 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x82 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x83 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x84 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x85 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x86 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x87 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x88 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x89 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x8a 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x8b 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x8c 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x8d 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x8e 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x8f 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x90 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x91 32 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x92 32 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x93 32 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x94 32 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x95 32 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x96 32 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x97 32 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x98 32 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
179 GLXFBConfigs:
0x99  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x9a  0 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x9b  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x9c  0 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x9d  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x9e  0 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x9f  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0xa0  0 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0xa1  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0xa2  0 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0xa3  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0xa4  0 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0xa5  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0xa6  0 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0xa7  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0xa8  0 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0xa9  0 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0xaa  0 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0xab  0 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0xac  0 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0xad  0 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0xae  0 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0xaf  0 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0xb0  0 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0xb1  0 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0xb2  0 dc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0xb3  0 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0xb4  0 dc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0xb5  0 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0xb6  0 dc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0xb7  0 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0xb8  0 dc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0xb9  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0xba  0 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0xbb  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0xbc  0 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0xbd  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0xbe  0 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0xbf  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0xc0  0 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0xc1  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0xc2  0 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0xc3  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0xc4  0 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0xc5  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0xc6  0 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0xc7  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0xc8  0 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0xc9  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0xca  0 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0xcb  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0xcc  0 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0xcd  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0xce  0 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0xcf  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0xd0  0 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0xd1  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0xd2  0 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0xd3  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0xd4  0 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0xd5  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0xd6  0 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0xd7  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0xd8  0 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0xd9  0 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0xda  0 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0xdb  0 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0xdc  0 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0xdd  0 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0xde  0 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0xdf  0 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0xe0  0 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0xe1  0 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0xe2  0 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0xe3  0 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0xe4  0 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0xe5  0 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0xe6  0 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0xe7  0 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0xe8  0 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0xe9  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0xea  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0xeb  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0xec  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0xed  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0xee  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0xef  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0xf0  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0xf1  0 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0xf2  0 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0xf3  0 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0xf4  0 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0xf5  0 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0xf6  0 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0xf7  0 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0xf8  0 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0xf9  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0xfa  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0xfb  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0xfc  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0xfd  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0xfe  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0xff  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x100  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x101  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x102  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x103  0 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x104  0 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x105  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x106  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x107  0 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x108  0 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x109  0 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x10a  0 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x10b  0 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x10c  0 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x10d  0 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x10e  0 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x10f  0 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x110  0 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x111  0 sg  0 16  0 r  y  .  5  6  5  0  4 16  0 16 16 16 16  0 0 None
0x112  0 sg  0 16  0 r  .  .  5  6  5  0  4 16  0 16 16 16 16  0 0 None
0x113  0 sg  0 16  0 r  y  .  5  6  5  0  4 24  0 16 16 16 16  0 0 None
0x114  0 sg  0 16  0 r  .  .  5  6  5  0  4 24  0 16 16 16 16  0 0 None
0x115  0 sg  0 16  0 r  y  .  5  6  5  0  4 24  8 16 16 16 16  0 0 None
0x116  0 sg  0 16  0 r  .  .  5  6  5  0  4 24  8 16 16 16 16  0 0 None
0x117  0 sg  0 16  0 r  y  .  5  6  5  0  4  0  0 16 16 16 16  0 0 None
0x118  0 sg  0 16  0 r  .  .  5  6  5  0  4  0  0 16 16 16 16  0 0 None
0x119  0 sg  0  0  0 r  .  .  0  0  0  0  4 16  0 16 16 16 16  0 0 None
0x11a  0 sg  0  0  0 r  .  .  0  0  0  0  4 24  0 16 16 16 16  0 0 None
0x11b  0 sg  0  0  0 r  .  .  0  0  0  0  4 24  8 16 16 16 16  0 0 None
0x11c  0 sg  0 32  0 r  .  . 16 16  0  0  4  0  0 16 16 16 16  0 0 None
0x11d  0 sg  0 32  0    .  . 16 16  0  0  4  0  0 16 16 16 16  0 0 None
0x11e  0 sg  0 32  0 r  y  . 16 16  0  0  4  0  0 16 16 16 16  0 0 None
0x11f  0 sg  0 32  0    y  . 16 16  0  0  4  0  0 16 16 16 16  0 0 None
0x120  0 sg  0 32  0 r  .  . 32  0  0  0  4  0  0 16 16 16 16  0 0 None
0x121  0 sg  0 32  0    .  . 32  0  0  0  4  0  0 16 16 16 16  0 0 None
0x122  0 sg  0 32  0 r  y  . 32  0  0  0  4  0  0 16 16 16 16  0 0 None
0x123  0 sg  0 32  0    y  . 32  0  0  0  4  0  0 16 16 16 16  0 0 None
0x124  0 sg  0 64  0 r  .  . 16 16 16 16  4  0  0 16 16 16 16  0 0 None
0x125  0 sg  0 64  0    .  . 16 16 16 16  4  0  0 16 16 16 16  0 0 None
0x126  0 sg  0 64  0 r  y  . 16 16 16 16  4  0  0 16 16 16 16  0 0 None
0x127  0 sg  0 64  0    y  . 16 16 16 16  4  0  0 16 16 16 16  0 0 None
0x128  0 sg  0 128  0 r  .  . 32 32 32 32  4  0  0 16 16 16 16  0 0 None
0x129  0 sg  0 128  0    .  . 32 32 32 32  4  0  0 16 16 16 16  0 0 None
0x12a  0 sg  0 128  0 r  y  . 32 32 32 32  4  0  0 16 16 16 16  0 0 None
0x12b  0 sg  0 128  0    y  . 32 32 32 32  4  0  0 16 16 16 16  0 0 None
0x12c  0 sg  0 32  0 r  .  . 16 16  0  0  4 24  0 16 16 16 16  0 0 None
0x12d  0 sg  0 32  0    .  . 16 16  0  0  4 24  0 16 16 16 16  0 0 None
0x12e  0 sg  0 32  0 r  y  . 16 16  0  0  4 24  0 16 16 16 16  0 0 None
0x12f  0 sg  0 32  0    y  . 16 16  0  0  4 24  0 16 16 16 16  0 0 None
0x130  0 sg  0 32  0 r  .  . 16 16  0  0  4 24  8 16 16 16 16  0 0 None
0x131  0 sg  0 32  0    .  . 16 16  0  0  4 24  8 16 16 16 16  0 0 None
0x132  0 sg  0 32  0 r  y  . 16 16  0  0  4 24  8 16 16 16 16  0 0 None
0x133  0 sg  0 32  0    y  . 16 16  0  0  4 24  8 16 16 16 16  0 0 None
0x134  0 sg  0 32  0 r  .  . 32  0  0  0  4 24  0 16 16 16 16  0 0 None
0x135  0 sg  0 32  0    .  . 32  0  0  0  4 24  0 16 16 16 16  0 0 None
0x136  0 sg  0 32  0 r  y  . 32  0  0  0  4 24  0 16 16 16 16  0 0 None
0x137  0 sg  0 32  0    y  . 32  0  0  0  4 24  0 16 16 16 16  0 0 None
0x138  0 sg  0 32  0 r  .  . 32  0  0  0  4 24  8 16 16 16 16  0 0 None
0x139  0 sg  0 32  0    .  . 32  0  0  0  4 24  8 16 16 16 16  0 0 None
0x13a  0 sg  0 32  0 r  y  . 32  0  0  0  4 24  8 16 16 16 16  0 0 None
0x13b  0 sg  0 32  0    y  . 32  0  0  0  4 24  8 16 16 16 16  0 0 None
0x13c  0 sg  0 64  0 r  .  . 16 16 16 16  4 24  0 16 16 16 16  0 0 None
0x13d  0 sg  0 64  0    .  . 16 16 16 16  4 24  0 16 16 16 16  0 0 None
0x13e  0 sg  0 64  0 r  y  . 16 16 16 16  4 24  0 16 16 16 16  0 0 None
0x13f  0 sg  0 64  0    y  . 16 16 16 16  4 24  0 16 16 16 16  0 0 None
0x140  0 sg  0 64  0 r  .  . 16 16 16 16  4 24  8 16 16 16 16  0 0 None
0x141  0 sg  0 64  0    .  . 16 16 16 16  4 24  8 16 16 16 16  0 0 None
0x142  0 sg  0 64  0 r  y  . 16 16 16 16  4 24  8 16 16 16 16  0 0 None
0x143  0 sg  0 64  0    y  . 16 16 16 16  4 24  8 16 16 16 16  0 0 None
0x144  0 sg  0 128  0 r  .  . 32 32 32 32  4 24  0 16 16 16 16  0 0 None
0x145  0 sg  0 128  0    .  . 32 32 32 32  4 24  0 16 16 16 16  0 0 None
0x146  0 sg  0 128  0 r  y  . 32 32 32 32  4 24  0 16 16 16 16  0 0 None
0x147  0 sg  0 128  0    y  . 32 32 32 32  4 24  0 16 16 16 16  0 0 None
0x148  0 sg  0 128  0 r  .  . 32 32 32 32  4 24  8 16 16 16 16  0 0 None
0x149  0 sg  0 128  0    .  . 32 32 32 32  4 24  8 16 16 16 16  0 0 None
0x14a  0 sg  0 128  0 r  y  . 32 32 32 32  4 24  8 16 16 16 16  0 0 None
0x14b  0 sg  0 128  0    y  . 32 32 32 32  4 24  8 16 16 16 16  0 0 None
m.e
Fedora package works
Postby m.e » Sat Jul 26, 2008 6:08 pm
I have installed the Fedora package, and that works.
m.e
