Error-catching in Clothes Listing
Postby MTKnife » Fri Dec 10, 2021 6:32 pm
I spent like an hour and a half trying to fix this last night, thinking it was because I changed the location of the "Documents" directory...before thinking to check the log.
This asset causes an encoding error:
http://www.makehumancommunity.org/cloth ... t_t01.html
I don't see any weird characters in the MHCLO or MHMAT files, at least not in the initial, text parts, but there's something there, and the asset should probably be taken down. Note that it's entirely possible that this is a Windows-only problem, since Windows doesn't play nicely with Unicode.
However, the asset isn't why I'm posting here in "Bugs": the error is being caught, thus preventing the app from crashing (Makehuman is quite good about error-catching), but it's being caught at the level of the entire listing, not the individual item of clothing. The result is that, in the "Clothes" tab, the app displays all the assets it loads before hitting the bad one, and then stops loading, leaving a partial listing. It would be better to catch the error at the level of the asset in question, and skip that one (while putting up a warning).
MTKnife
Re: Error-catching in Clothes Listing
Postby Ricardo2020 » Sat Dec 11, 2021 5:31 am
I have also seen this during my sessions as well. Perhaps there is a solution, but I was unable to find it.
The workaround is to remove the defective asset from the program directory. Typically, in Windows this will be inside the Documents folder. In Linux, it can be found in Home. Either way, the file will be in the Data folder within the MakeHuman folder inside whatever folder containing said asset. Send the asset folder to the recycle bin or put it in a holding folder so that you can dissect and troubleshoot the contents.
I feel it is better to try and find out what causes MakeHuman to burp on an asset rather than taking it down outright. Finding the solution could then be sent to the author of said asset so they can correct the files and repost them as an edit session from within their own logged in channel. I would want this pertaining to anything I post here which might cause a problem. Rather than take my stuff down due to a malfunction, I would want to fix it.
Has anyone else seen this problem mentioned in the post above? If so, tell us what your solution was. I am using the holding pattern method wherein I take it out of the data folder and put it in a holding folder outside the MakeHuan directory. This seems to solve the listing issue mentioned. Kind of like killing a fly with an atom bomb, since I do not know wnat caused the asset to malfunction.
Postby joepal » Tue Dec 14, 2021 9:26 am
Initial research shows that the asset works fine on linux. I'll try to set up a windows development environment to figure out what goes wrong.
Also, the asset does not contain any unicode characters. The MHMAT file is plain ASCII, while the MHCLO file is ISO-8859-1.
If you delete the line that starts with "# description: " in the mhclo file, does the error go away?
Postby joepal » Tue Dec 14, 2021 1:15 pm
Unfortunately, the asset works fine for me in windows too.
Can you attach a log where a crash or similar is visible?
Postby tomcat » Tue Dec 14, 2021 8:35 pm
I get the same error:
Exception during event onShow
  File "./core\events3d.py", line 211, in callEvent
    method(event)
  File "E:\makehuman-community\makehuman\plugins\3_libraries_clothes_chooser.py", line 146, in onShow
    super(ClothesTaskView, self).onShow(event)
  File "./apps/gui\proxychooser.py", line 473, in onShow
    self.filechooser.refresh()
  File "./lib\filechooser.py", line 894, in refresh
    super(ListFileChooser, self).refresh()
  File "./lib\filechooser.py", line 580, in refresh
    self.loadHandler.refresh(files)
  File "./lib\filechooser.py", line 459, in refresh
    tags = self.library.getTags(filename = file)
  File "./apps/gui\proxychooser.py", line 646, in getTags
    return filecache.MetadataCacher.getTags(self, filename)
  File "./lib\filecache.py", line 264, in getTags
    metadata = self.getMetadata(filename)
  File "./lib\filecache.py", line 240, in getMetadata
    self.updateFileCache(self.getSearchPaths() + [os.path.dirname(fileId)], self.getFileExtensions(), False)
  File "./lib\filecache.py", line 299, in updateFileCache
    self._filecache.update(search_paths, file_extensions, self._get_metadata_callback, remove_old_entries)
  File "./lib\filecache.py", line 152, in update
    self._cache[fileId] = (mtime,) + getMetadata(filepath)
  File "./lib\filecache.py", line 190, in _get_metadata_callback
    return self.getMetadataImpl(self.getMetadataFile(filename))
  File "./apps/gui\proxychooser.py", line 175, in getMetadataImpl
    return proxy.peekMetadata(filename, self.getProxyType())
  File "./shared\proxy.py", line 1025, in peekMetadata
    for line in fp:
  File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\codecs.py", line 322, in decode
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe9 in position 187: invalid continuation byte
Win 7. DecodeError …but I don't have a D: drive.
— Are birds being milked there?
— In Russia everyone is milked. Here even zucchinis lay caviar…
Postby joepal » Thu Dec 16, 2021 3:23 pm
That's very odd. But at least I can add a try/catch block around that specific location in order to avoid having it influence the rest of the assets.
Postby joepal » Thu Dec 16, 2021 3:45 pm
Potential "fix" in https://github.com/makehumancommunity/m ... 254f96d44c ... It isn't really a fix though, just a last-resort fallback to avoid having the entire list getting ruined by a broken asset.
But reading the code further down in the stack, I don't really see how the error could arise in the first place. Also, the line indicated in the stack trace is off by one compared with the current master. On what version of MH does the problem arise?
Postby tomcat » Thu Dec 16, 2021 4:39 pm
joepal wrote:On what version of MH does the problem arise?
Bug in 1.2.0 final (HEAD:c28443c2). In version 20211206 alpha (HEAD:1944525e) everything works fine and Jacket is displayed and put on correctly.
Potential "fix"...
Yep, everything works with this version. Well thank you!
Postby punkduck » Sat Dec 18, 2021 4:54 pm
oooops sorry wasn't here for a few days.
Yes woodcat. Flute was the first who had the problem, then Ricardo. Furthermore it depended if the object was an mhclo or a compiled mhpxy file already. Old MakeHuman was able to read it, new one not. So if an mhpxy was migrated the comment was not used and new one worked fine.
It was the Jacket01 (or similar) and it was an é in a comment .. I did the fix and the fix was simply ignoring coding-errors while reading lines ;)
