MakeClothes2 --- What's this about?
Postby SaltyCowdawg » Thu Aug 27, 2020 4:08 pm
It's been almost a year since I last used MakeClothes2 so this could be some form of PEBKAC issue.
Mashed the button, clothes not made and go the following in Blender.
  File "/home/peter/.config/blender/2.83/scripts/addons/makeclothes/operators/createclothes.py", line 103, in execute
    mc = MakeClothes(clothesObj, humanObj, exportName=name, exportRoot=rootDir, license=license, author=author, description=desc, context=context)
  File "/home/peter/.config/blender/2.83/scripts/addons/makeclothes/core_makeclothes_functionality.py", line 155, in __init__
    if MAKESKIN_VERSION >= LEAST_REQUIRED_MAKESKIN_VERSION:
TypeError: '>=' not supported between instances of 'tuple' and 'int'
Any thoughts?
Re: MakeClothes2 --- What's this about?
Postby punkduck » Thu Aug 27, 2020 9:42 pm
SaltyCowdawg wrote:It's been almost a year since I last used MakeClothes2 so this could be some form of PEBKAC issue.
Any thoughts?
arrgh .. :oops:
makeskin has a version number of 3 components (0, 9, 0) ... and LEAST_REQUIRED_VERSION in utils is an integer => results in a python hiccup
I will change that (or Joel).
Since you work with Linux you can get a positive result earlier, so quick (and in a way stupid) workaround until then: in the file where the program complains change:
in
if 2 > 1:
(which is always true). Otherwise that tool won't work until it is fixed (maybe tomorrow evening, not yet it is midnight over here ) ...
We will bundle these tools, I guess ...
Postby SaltyCowdawg » Fri Aug 28, 2020 12:41 pm
punkduck wrote:
if 2 > 1:
Somewhere in the world I am sure is a math geek who has found a math proof that says otherwise! :-D
I will make the change... a hacking I will go...
Postby punkduck » Fri Aug 28, 2020 1:22 pm
Yupp Elv mentioned, that you had a problem. Well it is good that you found that.
Joel improved the presentation of the version numbers in MakeSkin and I changed the same for MakeClothes, so the number is shown in menu (to answer questions later etc.).
Internally Makeclothes asks for a valid version to include MakeSkin .. and crashed. I just did a hotfix directly in the master of MakeClothes. So github is already okay. At least on my box it runs now.
Funny:
Yesterday I really was too tired, just wanted to give an answer and didn't remember that ">=" also works for complete arrays in python correctly (I am a perl and C guy mostly) :roll:
LEAST_REQUIRED_MAKESKIN_VERSION = (0,9,0) in utils.py would have been the better hack ;)
