Makehuman blender plugin error
Postby bogdan666 » Sat Jan 04, 2020 4:18 pm
Whenever I try to import a mesh through MakeHuman v 0.6.2 in Blender 2.80 this is what I get an no mesh gets loaded:
What could cause this? I've installed the lastest MakeClothes 2 and makehuman plugin.
bogdan666
Re: Makehuman blender plugin error
Postby RobBaer » Sat Jan 04, 2020 8:41 pm
bogdan666 wrote:Whenever I try to import a mesh through MakeHuman v 0.6.2 in Blender 2.80 this is what I get an no mesh gets loaded:
I don't know what format you are talking about using, but MH 0.6.2 is so OLD that I would be quite surprised if it to work. The entire design, including the base mesh, was different back then. I think that was even before .mhx was first written. I don't know what export formats were supported back then. Did you try something basic like .obj export?
Postby bogdan666 » Sun Jan 05, 2020 8:00 am
I've downloaded the latest version and it states that it's 0.6.2. (from January 2020)
I'm not talking about MH itself but about the Makehuman blender 2.8 plugin + MakeClothes2.
And I've got the newest MH Alpha 4 installed.
Plugins downloaded from this site:
http://download.tuxfamily.org/makehuman/plugins/ (.....latest.zip)
bogdan666
Postby joepal » Sun Jan 05, 2020 12:33 pm
It says "connection refused", right?
Did you start the socket server in makehuman? You need to do so explicitly by going to the community -> socket tab and start the socket server.
Postby bogdan666 » Sun Jan 05, 2020 2:33 pm
Ok, works!
Didn't know that I had to open MH for this and check "accept connections".
bogdan666
Postby olesatchel » Mon Aug 31, 2020 1:59 pm
I tried accepting connections and it crashed my makehuman and it keeps doing that. What do I need to do to fix it please?
Thanks,
olesatchel
Postby joepal » Mon Aug 31, 2020 4:19 pm
olesatchel wrote:I tried accepting connections and it crashed my makehuman and it keeps doing that. What do I need to do to fix it please?
Thanks,
It should obviously not crash MH. But this is not info enough to help you figure out what is wrong.
See http://www.makehumancommunity.org/wiki/ ... _report%3F
