r2336: Startup sequence broken
Postby mcc » Wed Apr 27, 2011 5:49 pm
System:
Gentoo Linux, update status of this morning, 4:30 MESZ (yes, in the morning).
Linux Kernel 2.6.38.4 64bit
Python 2.6.6 (r266:84292, Feb 26 2011, 16:21:53)
[GCC 4.4.4] on linux2
CPU: AMD Phenom(tm) II X6 1090T Processor
Graphics: GeForce GT 430 nvidia (by MSI)
Driver: nvidia 270.41.03
Screen: 1920x1200
(I only will report this again if something related will change)
When starting makehuman from the commandline, the dump says:
solfire:/home/mccramer>makehuman
solfire:/home/mccramer>Version 1.0.0
Asymmetry loaded
Face imported
Face loaded
Measurement loaded
Random imported
Ethnics imported
BVH Player loaded
Expression imported
Expression loaded
Pose2 plugin imported
pose loaded
Skeleton loaded
Background chooser loaded
Texture chooser loaded
POV-Ray Export Parameter File
povray imported
Povray loaded
Rendering setting imported
Settings imported
File "main.py", line 288, in loadNextPlugin
module.load(self)
File "plugins/5_settings_shortcuts.py", line 74, in load
taskview = ShortcutsTaskView(category)
File "plugins/5_settings_shortcuts.py", line 34, in __init__
gui3d.TextView(self.cameraBox, [18,y + 5, 9.2], "Right view", 47, 2);AppShortcutEdit(self.cameraBox, [68,, 9.2], self.app.rightView);y+=25
File "plugins/5_settings_shortcuts.py", line 9, in __init__
gui3d.ShortcutEdit.__init__(self, parent, position, parent.app.getShortcut(method))
File "./core/gui3d.py", line 1985, in __init__
self.shortcutToLabel(shortcut[0], shortcut[1]))
TypeError: 'NoneType' object is unsubscriptable
Could not load 5_settings_shortcuts
Help imported
Pose plugin imported
pose loaded
Unable to open data/targets/macrodetails/universal-male-young.target
Unable to open data/targets/macrodetails/universal-female-young.target
The Traceback dump flags an error condition.
Trying to load non existing files flag some old/no longer valid code, which should be removed.
Best regards,
mcc
mcc
Re: r2336: Startup sequence broken
Postby jcapco » Wed Apr 27, 2011 11:59 pm
delete your old inis and try again
jcapco
Postby mflerackers » Thu Apr 28, 2011 12:03 am
The
is known, it is due to 'wildcard' replacement creating target names which shouldn't be used.
MakeHuman project Developer
mflerackers
Postby mflerackers » Thu Apr 28, 2011 6:57 am
You need to delete shortcuts.ini, the loading code is still shaky and can't take changes good.
mflerackers
