First of all I would like to say that Makehuman software is excellent.
Second, I’m a newbie but I’ve spend several hours digging into the forum and I’ve didn’t found it, so if by chance the same problem is on another disc. I demand to the Admin to put the link page as an answer please.
I run windows 7 64 bits, and downloaded the last version of Makehuman (1.0 alpha 5.1).
When I start the application I’ve get on the log “import site failed; use –v for traceback” (don’t know if it is normal or not)
The problem is that when I tried to save, nothing happens… only get an UnicodeEncodeError: ‘ascii’ codec can’t encode character u’\xe9’ in position 12:
original out not in range<128>
Same thing exporting to .obj
Exporting in .dae LookupError: no codec searsh functions registred: can’t find encoding
I have ascii installed, as I’ve saw it on another post… the srange is that Makehuman 0.9.1 works fine… but I would like to upgrade…
All that I need is to export in .obj to work with a third-party software.
Thank you for your time
joseartur
