Nightly Build 1-20-11 wont start
Postby Blacksage » Sat Jan 22, 2011 12:10 am
I downloaded the nightly build yesterday, after extraction I went to run the .exe
Everything seemed normal when my progress bar reached about 75% or so then it stalled and my console printed the following errors.
Version 1.0.0
Could not load data/themes/default/images/data/hairs/default.png, Couldn't open
aqsis imported
Could not load aqsis
'Rendering'
Could not load asymm
__init__() got an unexpected keyword argument 'width'
Expression imported
Could not load expression
hair properties imported
Could not load hair_properties
makehair plugin
Storing mesh status
'aqsl' is not recognized as an internal or external command,
operable program or batch file.
Could not load makehair
Could not load measurement
Pose plugin imported
Could not load pose
Could not load rendering_aqsis
Could not load rendering_setting
Could not load settings_settings
File "<string>", line 1, in <module>
File "main.py", line 403, in <module>
application = MHApplication()
File "main.py", line 205, in __init__
focusedTexture=self.getThemeResource('images', 'button_tab3_focused.png'), h
eight=22)
TypeError: __init__() got an unexpected keyword argument 'selectedTexture'
Could not run main Python script
Blacksage
Re: Nightly Build 1-20-11 wont start
Postby mflerackers » Sat Jan 22, 2011 12:35 am
Yup, as I said here http://code.google.com/p/makehuman/issu ... l?id=84#c1 the nightly was probably taken while we were committing changes. The version in svn works.
The nightly builds are never guaranteed to work, as they are build automatically. So they are a snapshot of the code at a certain moment. It looks like in the nightly you have, gui3d.py is not in sync with the other files.
MakeHuman project Developer
mflerackers
Postby Blacksage » Sat Jan 22, 2011 1:44 am
Thanks for the fast response.
I run windows xp what software would I need to get my hands on the svn?
Blacksage
Postby mflerackers » Sat Jan 22, 2011 1:52 am
http://code.google.com/p/makehuman/source/checkout, an svn client (http://tortoisesvn.tigris.org/) and gcc/mingw or visual C++ express (http://www.microsoft.com/express/Downlo ... Visual-CPP) to build the exe. If you're not a developer, I would advise to wait for the next nightly :).
mflerackers
Postby Blacksage » Sat Jan 22, 2011 2:10 am
I have not ran a copy of visual C++ in years, awesome it feels like programming 3 all over again! :D it looks like I'm gonna have to dust off my programmer hat. I'll take your advice and wait for the nightly for now but I imagine that I'll be downloading all that sometime soon. thanks again for the quick response.
Blacksage
Postby blalan » Mon Jan 24, 2011 7:59 am
I have been having the same problem, with the same nightly builds and all of the following. I am running Win7(32bit) and download the nightly build daily. Ever since the 20th I have not been able to launch the exe. I get the splash screen, it loads then disappears.
blalan
Postby joepal » Mon Jan 24, 2011 10:36 am
There is the additional problem that the nightlies have been down for two days since I have been rebuilding the build farm a bit. You are thus probably still downloading the version from the 20th.
New versions should appear during the night.
Postby blalan » Mon Jan 24, 2011 8:35 pm
Ok, yes I just looked and in the nightly builds the "last modified" date, is still the 1/20/11, thank you for you help. I can't wait for a beta to come!!!! awesome job guys. Thanks!
blalan
Postby jwilwade » Tue Jan 25, 2011 12:56 am
I downloaded the nightly build listed on Jan 24th and it crashes my Computer every time I try to run it. Now I had the previous nightly build from about a week ago maybe two and it worked fine and the regular version 5.1 works well. Just a huge problem with the latest release. I there a way to get a list of the releases by date so I can download again the previous one?
jwilwade
Postby mflerackers » Tue Jan 25, 2011 2:03 am
Seems you downloaded the one from the 20th of January, there is no 24th build yet.
.makehuman-nightly-linux-amd64.tbz2.ApcLbP 2010-Aug-30 13:12:26 19.5M application/octet-stream
makehuman-nightly-linux-amd64.deb 2011-Jan-22 06:38:42 47.7M application/x-debian-package
makehuman-nightly-linux-amd64.tbz2 2011-Jan-22 06:37:10 50.8M application/octet-stream
makehuman-nightly-linux-i386.deb 2011-Jan-22 06:57:21 47.5M application/x-debian-package
makehuman-nightly-linux-i386.tbz2 2011-Jan-22 06:55:38 50.6M application/octet-stream
makehuman-nightly-osx.zip 2011-Jan-24 04:14:42 50.9M application/zip
makehuman-nightly-win32.zip 2011-Jan-20 05:27:10 58.8M application/zip
mflerackers
Users browsing this forum: Google [Bot] and 5 guests
