Can't save or export. 5.1.
Postby Pitt78 » Sun Dec 05, 2010 5:27 am
Just installed the latest build of MH, and it won't let me save or export? I hit save, nothing happens. I hit export and the file options come up but that is it.
Pitt78
Re: Can't save or export. 5.1.
Postby mflerackers » Sun Dec 05, 2010 6:01 am
Did you type a name to save to? What is the console output? What system (I guess windows)?
MakeHuman project Developer
mflerackers
Postby Pitt78 » Sun Dec 05, 2010 7:29 am
Course I typed a name:). Not sure what you mean by console output, yes windows 7.
Pitt78
Postby joepal » Sun Dec 05, 2010 12:17 pm
For console output:
  • Start a dos prompt. If you have "run" on the start menu, choose that and enter "cmd". If not, press WINKEY+r and enter "cmd".
  • Navigate to the makehuman directory. You use the command "cd" to change directory. For example "cd \" to move to the root of c: and then "cd program" and so on until you find the makehuman directory.
  • Enter "makehuman.exe" to run makehuman.
  • Try to save stuff
  • Close makehuman.
With some luck you should see an error message printed in the dos window now.
Postby Pitt78 » Sun Dec 05, 2010 6:48 pm
Sorry, you lost me at the use "cd" to change directory part:(
Pitt78
Postby primaveranz » Mon Dec 27, 2010 3:55 am
I am running on XP SP 3 3Gb Ram, Plenty HDD space, Hewlett Packard, Intel i5 CPU 660 @ 3.33 GHz. MS C++ redistributable installed etc.
I have just installed 1.0 Alpha 5.1 and have the same problem. I get these messages on start up:-
'import site' failed; use -v for traceback
Version 1.0.0
Asymm loaded
hair properties imported
hair properties loaded
makehair plugin
Storing mesh status
Asymm loaded
Pose plugin imported
pose loaded
'aqsl' is not recognized as an internal or external command,
operable program or batch file.
r batch file.♪◙'aqsl' is not recognized as an internal or external command,ram o
Rendering setting imported
Settings imported
('setFocus', <gui3d.Slider instance at 0x02A5C710>)
updated 15340 vertices
And this when I try to Save:-
Version 1.0.0
Asymm loaded
makehair plugin
Storing mesh status
Asymm loaded
pose loaded
Settings imported
any clues?
Thanks.
primaveranz
Postby mflerackers » Mon Dec 27, 2010 4:23 am
Do you have aqsis (http://www.aqsis.org/) installed?
mflerackers
Postby primaveranz » Mon Dec 27, 2010 7:56 am
mflerackers wrote:Do you have aqsis (http://www.aqsis.org/) installed?
Err...No. I'll go and do that now. Thanks! ;)
primaveranz
