Program not working
Program not working
Postby jwilwade » Tue Aug 24, 2010 1:01 pm
Can not export, Save, render, and the ethnic mix menu is not there Have installed vista x64 windows 64bit 8 gig mem quad core. PovRay v.3 has been installed and is the correct folder location. The program seems to work at modeling but not the hair and I can not export OBj.BVH I have not tried blender export as I do not use blender.
jwilwade
Re: Program not working
Postby mflerackers » Tue Aug 24, 2010 1:13 pm
What version did you install, alpha5 or nightly?
MakeHuman project Developer
mflerackers
Postby jwilwade » Tue Aug 24, 2010 3:51 pm
Alpha 5
jwilwade
Postby mflerackers » Tue Aug 24, 2010 3:57 pm
What's the output in the console? Are there permission warnings?
mflerackers
Postby jwilwade » Tue Aug 24, 2010 4:30 pm
No I run Vista x64 as administrator. The only thing I see is Color not located or something to that affect. The programs says it is loading something but never loads anything. I will install it again and try to capture the code it produces when I try to export a mesh o render or save.
jwilwade
Postby jwilwade » Tue Aug 24, 2010 4:45 pm
Loading Data but nothing ever gets loaded.
This program simply does not work.
jwilwade
Postby jwilwade » Tue Aug 24, 2010 4:46 pm
even when I try to render and I clearly have pov Ray v.3 installed and located correctly it gives me only the Aqueis or what ever it is option and never renders anything.
jwilwade
Postby mflerackers » Tue Aug 24, 2010 5:09 pm
There's no maintainer for the pov script at the moment.
mflerackers
Postby jcapco » Tue Aug 24, 2010 8:26 pm
Regarding your not seeing any renders. That's because you probably have not installed aqsis. Try installing aqsis here.
At the moment, we only support rendering by aqsis. If you aren't happy with aqsis, the only other way is by exporting the created model and using a third party software (like blender, maya.. etc.) to import the exports and render it there.
PovRay is currently stalled, but not dead. We will come back to it sometime. I will want to maintain Pov codes (I plan to make it pov 3.0 to 3.5 compatible) once my tasks are reduced.
jcapco
Postby jwilwade » Wed Aug 25, 2010 3:02 pm
Ok I will install aqsis. I will reinstall the Make Human program and try it again,. However this still does not solve the problem of why I can not export the model as OBJ so it could be used in another program.
jwilwade
